06-08-2016, 09:20 PM
Did look good at Pugfest guessing your running 21mm bars or some upgraded bars of some sort to lift the rear wheel? Sure ive only seen it on certain Gti6s
(06-08-2016, 09:20 PM)MY95 Wrote: [ -> ]Did look good at Pugfest guessing your running 21mm bars or some upgraded bars of some sort to lift the rear wheel? Sure ive only seen it on certain Gti6s
(20-08-2016, 08:16 PM)Danny Wideboy Wrote: [ -> ]Bollox will you.
You'll just take off another bit, paint it and put it back on again.
Just take inspiration from a certain Mr Rowel.
Did his in a weekend with Toms and Bates for help, how hard can it be?
(03-09-2016, 07:59 AM)Matt-Rallye Wrote: [ -> ]those are some porn brakes!!!
(03-09-2016, 05:24 PM)Eeyore Wrote: [ -> ]So what calipers are these?
(04-09-2016, 12:49 AM)ozonehostile Wrote: [ -> ]New brakes fitted tonight while I was waiting for the Mrs.
305mm rotors
Ebc yellow stuff pads
6 pot caliper
Perfect fit inside a 16" rim, and the best bit is that I've gone from having a cigarette paper of clearance between caliper and wheel to over 15mm compared with the previous 406 brembos!
Not had much of a drive yet as it was horrible weather but first impressions are a very good improvement over the old setup and that wasn't exactly a bad one!
Also fitted some Peugeot numberplate surrounds as I've always thought about getting some to fill out the 306 plate recesses a bit better
(04-09-2016, 12:12 PM)Pingaz Wrote: [ -> ](04-09-2016, 12:49 AM)ozonehostile Wrote: [ -> ]New brakes fitted tonight while I was waiting for the Mrs.
305mm rotors
6 pot caliper
Wow, what a nice brake setup ! Lovee that mate !
Sorry if you mention before I didn't see. What is the ET on that wheels ? I'm about to buy the same ones, Pro Race 1.2 right ?
PS: Lovely 6 mate I wish that I can be on the next hill climb
(07-09-2016, 09:40 PM)Pingaz Wrote: [ -> ]Wow
You had braided lines with the brembos ? You had to buy 406 lines or the 306 ones its fine for that caliper ?
(07-09-2016, 09:50 PM)ozonehostile Wrote: [ -> ](07-09-2016, 09:40 PM)Pingaz Wrote: [ -> ]Wow
Yeah I had braided, use a 306 flexi to a little adapter made out of copper brake pipe
(09-09-2016, 02:42 PM)Eeyore Wrote: [ -> ]looks rubbish as always. :/ So is it possible to get the brakes not trhough p1off and save money? or are the adapters p1off design?
(08-09-2016, 07:42 PM)Pingaz Wrote: [ -> ](07-09-2016, 09:50 PM)ozonehostile Wrote: [ -> ](07-09-2016, 09:40 PM)Pingaz Wrote: [ -> ]Wow
Perhaps you have a picture ? I couldn't find on this post maybe i'm blind ? I think will do the same with the brembos on my S16 but i really need to know that it was good and plug and play. I know that in the hub this all ok, and you need 16" alloys.
Thank you
(10-09-2016, 08:37 AM)ozonehostile Wrote: [ -> ](08-09-2016, 07:42 PM)Pingaz Wrote: [ -> ](07-09-2016, 09:50 PM)ozonehostile Wrote: [ -> ](07-09-2016, 09:40 PM)Pingaz Wrote: [ -> ]Wow
Thank you
Here's the 90 degree elbow you need, easy enough to make if you're handy with a brake flaring tool and they do fit under 15" wheels even with the 288mm xantia discs, the biggest issue is space between the caliper face and the back of the rim as these calipers are extremely chunky!
My new 6 pot setup has gained me about 15mm from where there was only a cigarette paper of clearance before
(20-09-2016, 07:13 PM)welshpug Wrote: [ -> ]much older is its a full box, looks similar to a magnex?
iirc both used to be a collins performance brand.
