(25-04-2016, 08:53 AM)Magenta Sunset Wrote: [ -> ]what's? the plywood for?
its a copy of the Peugeot tool for locking the camshaft pulleys to enable the centre bolt to be torqued up correctly
attachment=27361]
(25-04-2016, 09:03 AM)cully Wrote: [ -> ] (25-04-2016, 08:53 AM)Magenta Sunset Wrote: [ -> ]what's? the plywood for?
clever stuff!
Ah nice one cully, I was trying to think of who I'd seen that had made something for the job
pin the flywheel and the cam pulleys job done
My bodies are fitted... I win. You lose. WINNNARRRR
those arches look mint... Mine do not... I'm jealous...
(25-04-2016, 07:02 PM)Eeyore Wrote: [ -> ]My bodies are fitted... I win. You lose. WINNNARRRR
Yeah but sam you havent even taken your skirts off so when your car snaps in half from bwarps and zakks does not.. our reasoning will make sense
It won't snap in half, the skirts are holding it together fine atm...
Not much done recently, but I've been cleaning bits whilst they're off the car, it's the little things that count when trying to tidy up an ageing car like these 306s
Dishwasher?
(30-04-2016, 07:14 PM)Paul_13 Wrote: [ -> ]Dishwasher?
Steam cleaner haha
Matt came over today and shit got done for once
Cambelt is now spot on after making some tools to tension it properly and make the job alot easier in the future, quite glad I did decide to do the belt as it was looking a bit worn and to me seemed a bit slack.
Also started to put my new beam back together with the powdercoated bits and new wheel bearings
attachment=27476]
(01-05-2016, 06:53 PM)ozonehostile Wrote: [ -> ]Matt came over today and shit got done for once
What size are those bolts? Replacing my beam soon, and would be nice with some new nuts and bolts
All the bolts on the rear beam are various lengths of m12 and m8
New beam ready to bolt up. It looks too good to fit to the underside of a car haha
attachment=27503]
looks good zac! id advise you turning the rear mounting bolts around tho as you may not be able to get them out again when needed.
(02-05-2016, 07:42 PM)Stef205 Wrote: [ -> ]looks good zac! id advise you turning the rear mounting bolts around tho as you may not be able to get them out again when needed.
Ah good point actually, I'll change them around tomorrow
just dont make the misstake with the top shock bolt!
Looks good, that beam is soo shiny! What rear hubs/wheel bearings did you use? they look as shiny aha, got some conti direct continentals to go on mine
(02-05-2016, 11:25 PM)MY95 Wrote: [ -> ]Looks good, that beam is soo shiny! What rear hubs/wheel bearings did you use? they look as shiny aha, got some conti direct continentals to go on mine
I got a pair of FAG rear hub assemblys, try to only use skf or fag when it comes to bearings for anything as that's what would be oem fitted by pretty much every manufacturer
Ah cheers Ozone
Will see how these will last, were only £28 posted so!
I also have solid beam mounts and really like them, can get a little more skittish over rough ground though compared to standard mounts though, other than that and a bit more vibration, I find them really good
Future/coming up shortly plans for your car?
fag is genuine aswell
Tonights activities mostly involved un-seizing this wonderful contraption....
attachment=27526]
All great when it works but it had managed to seize fully closed this time, took alot of plusgas to get it moving at all! Hopefully it should be good for a while after the cleaning it's going to get
Oh, and I changed the bolts around on the beam for future ease of beam mount removal
Boot floor is finished now, just got a lot of masking tape to peel off and brake lines to put back on, then time to fit the new beam
attachment=27617]
Looking good pal....considering hidden brake lines like the scoobys n evos?!
(11-05-2016, 05:09 AM)Piggy Wrote: [ -> ]Looking good pal....considering hidden brake lines like the scoobys n evos?!
Eventually Yeah, I'd like to sack off the compensator too eventually and go for a manual bias valve but at the moment I'm having to compromise on some things so that it actually gets on the road this year..
Thats looking good now mate
give me a call when you wanna get the beam on and we'll have an evening on it
Refurbished brake compensator back together and painted
attachment=27656]
And finally have the new beam fitted! Bit of a balancing act with a couple of jacks and several axle stands doing it by myself but wasn't too bad really
attachment=27657]
Also got the rear bumper back on and I'll start to refit all the brake lines etc tomorrow
Got a couple more hours in today, beam mounts tightened, hub nuts tightened (200nm!), brake lines all cleaned up a treat with some thinners and started to put all the brackets and heat shields I had powdercoated back on.
Just have an order I'm waiting for from spoox motorsport to arrive then that should be everything I need to get it back together and ready for pugfest
