If you want, you can get some eibach 30's and swap them for my h&r 40-45's?
(09-02-2016, 11:35 AM)Razorback_Rob Wrote: [ -> ]^ I'm sure he's got that covered. Especially given his new line of work [emoji28]
why, is he a suspension guru that knows how to make suspension work properly? I doubt it given the ride height
(09-02-2016, 01:47 PM)welshpug Wrote: [ -> ] (09-02-2016, 11:35 AM)Razorback_Rob Wrote: [ -> ]^ I'm sure he's got that covered. Especially given his new line of work [emoji28]
No but fabricating suspension and other components on a Renault 5 turbo as a daily bread and butter must be a pretty nifty trade to work in. I see nothing wrong with the ride height, it handles incredibly.
(09-02-2016, 01:58 PM)Razorback_Rob Wrote: [ -> ]it handles incredibly shit.
yep.
Welshpug makes a statement...
Backs it up with abuse.
/Forum
(09-02-2016, 06:20 PM)Piggy Wrote: [ -> ]Welshpug makes a statement...
/Forum
Tbf, he will technically be right, hence Eibach only dropping 30mm for performance instead of looks, but whether it's noticeable in the real world is a different story!
less talk of ride height, more throttle bodies
(09-02-2016, 09:13 PM)zx_volcane Wrote: [ -> ]less talk of ride height, more throttle bodies
seconded.
Talk of ride height aside (it will be raised btw) I've managed to aquire a mk1 xsara vts steering rack. As they don't have the 6 speed box I was wandering if the wheel would hit the gearbox without the built in stop of a 6 rack?
the ram has the stop not the rack i believe
(14-02-2016, 07:39 PM)Stef205 Wrote: [ -> ]the ram has the stop not the rack i believe
Ah tidy, just a case of using the ram off the 6 rack then
Got another 2.4 rack? They seem to be very difficult to find.
(14-02-2016, 07:41 PM)Eeyore Wrote: [ -> ]Got another 2.4 rack? They seem to be very difficult to find.
Mk1 vts are 2.2 racks aren't they?
(14-02-2016, 07:53 PM)ozonehostile Wrote: [ -> ] (14-02-2016, 07:41 PM)Eeyore Wrote: [ -> ]Got another 2.4 rack? They seem to be very difficult to find.
Yeah the 2.2 are the quick racks
(14-02-2016, 08:25 PM)7057sam Wrote: [ -> ] (14-02-2016, 07:53 PM)ozonehostile Wrote: [ -> ] (14-02-2016, 07:41 PM)Eeyore Wrote: [ -> ]Got another 2.4 rack? They seem to be very difficult to find.
Excellent
(14-02-2016, 08:49 PM)Stef205 Wrote: [ -> ]ph1 2.4 ph2 2.6
this was my understanding!
Yah 2.4 ph1 - got one on the zx, it's dope. Has a square drive, I had to change my lower steering column as Zx comes with splined standard, dunno about 306.
(14-02-2016, 09:26 PM)zx_volcane Wrote: [ -> ]Yah 2.4 ph1 - got one on the zx, it's dope. Has a square drive, I had to change my lower steering column as Zx comes with splined standard, dunno about 306.
I'm sure the 306 is also splined, didn't think of that, may have to take a trip back and get some more parts of the vts breaker
Hah I didn't think of it either till I offered it up :/
306 lower column to rack is square drive, zx's are splined, joint to uppers column is splined on them all.
Not sure when they changed from spline to square on the pas racks, might be late zx's with square racks.
(15-02-2016, 11:13 PM)welshpug Wrote: [ -> ]306 lower column to rack is square drive, zx's are splined, joint to uppers column is splined on them all.
Ah that's good news then, is it 205 that are splined that I'm thinking of?
yeah, all 205's pas were splines, manual 205 racks changed from splined to square in 1990
The quick rack is 2.4, came off the phase 1 xsara vts. And yes when I fitted mine I realised you need your standard '6 ram otherwise it'll clip the gearbox on full lock and fail it's test!
(17-02-2016, 06:53 PM)Orta Wrote: [ -> ]The quick rack is 2.4, came off the phase 1 xsara vts. And yes when I fitted mine I realised you need your standard '6 ram otherwise it'll clip the gearbox on full lock and fail it's test!
It was you I was thinking of when wandering how to put the gti6 stop in when changing racks, matts black rallye is missing the inhibitor and has worn the gearbox cap smooth from wheel contact!
(18-02-2016, 04:34 AM)ozonehostile Wrote: [ -> ] (17-02-2016, 06:53 PM)Orta Wrote: [ -> ]The quick rack is 2.4, came off the phase 1 xsara vts. And yes when I fitted mine I realised you need your standard '6 ram otherwise it'll clip the gearbox on full lock and fail it's test!
Oi! mines just making itself even lighter as it goes
Haha, shaving the weight off a few grams at a time :p
First load of bits off to be powder coated, be a shame to fit a shiny new beam with tatty brackets and Shields
Finally picked up the new beam. Huge thanks to stef for sorting it, just waiting for parts to come back from the powder coaters and I'll get it refitted
