XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Important Threads
- XUD RR results *THE BIBLE* (211 Replies)
- How To - 2.1TD Swap / XUD11 Fitting (101 Replies)
- Another Warning: Run away Diesels (75 Replies)
- LDA pins, Injector refurbs, Pump mods blah blah (91 Replies)
- Warning: Bypassing the Heater Matrix - DON'T DO IT! (41 Replies)
- torque settings (10 Replies)
Threads
- N/A head on a Turbo engine=Bad idea or not? (3 Replies)
- Main Fuel Screw and Idle Speed (6 Replies)
- FORGED XUD - new oil pump? (2 Replies)
- Changing Speed Sensor (4 Replies)
- Read only???? Also head studs question (1 Reply)
- which clutch for 500 nm? (1 Reply)
- How to remove pulley from steering pump (1 Reply)
- How to remove pulley from steering pump (0 Replies)
- Black Smoke - help (1 Reply)
- 306 1.9 lx Fan running when ignition off (1 Reply)
- XUD9 Valve clearances (8 Replies)
- Suzuki Vitara XUD9 tuning (29 Replies)
- New clutch cable needed (3 Replies)
- Is LDA pin grind worth it with K03? (7 Replies)
- Lucas pump cap (7 Replies)
- Priming Bulb Not Holding Pressure (4 Replies)
- Slack in bosch pump? (14 Replies)
- Cylinder head manni surface sanding (9 Replies)
- Project dirty deezel 206 1.1 to XUD9TE :D (10 Replies)
- Flow vs psi? (19 Replies)
- Xud9 White smoke and primer wont stay hard (5 Replies)
- Piston Anti-Friction Coating (2 Replies)
- Bosch VE firing order (1 Reply)
- Bosch VE firing order (0 Replies)
- Xud9 coolant pipes at rear of engine (1 Reply)
