XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- Help with lda setup/ 2nd to 3rd gear lagging :( (24 Replies)
- Bosch injectors issue (18 Replies)
- turbo fitment (13 Replies)
- Fair size hole in my gearbox casing!! (21 Replies)
- What hose? (9 Replies)
- What air con pump? (3 Replies)
- knocking (2 Replies)
- Throttle cable changing (5 Replies)
- Vegy tar on chassis (13 Replies)
- Difference between phase 2 xud and hdi dial clusters? (5 Replies)
- Help/Advice needed for Wiring in 205 STDT Tacho Counter (11 Replies)
- Bosch pump (22 Replies)
- Xantia inlet gasket (13 Replies)
- Cheap German turbos (21 Replies)
- VHC of a N-reg phase 1 306 1.9 (non turbo) (18 Replies)
- turbo rebuild issue (14 Replies)
- manual boost controler (14 Replies)
- Omp strut brace fow brake res (10 Replies)
- Help :( (6 Replies)
- Head change- do the studs need replacing? (16 Replies)
- TD04L Inlet Size (9 Replies)
- Stage 1 guide (11 Replies)
- white smoke and rough idle (4 Replies)
- Where to buy fuel hose? (7 Replies)
- Standard Oil Cooling (6 Replies)
