XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- Bosch removal with pulley intact (3 Replies)
- XUD7, XUD9 and upgrade conrods (4 Replies)
- DW8 Timing belt cover / water pump bolt size? (13 Replies)
- 306 d turbo (5 Replies)
- The judge and its xud11 (37 Replies)
- 1.9 12v head (4 Replies)
- pump oil xud9te or xud11bte (0 Replies)
- Boost seems to be coming in later?? Any ideas? (11 Replies)
- Massive oil leak (8 Replies)
- Will a T2 turbo fit on a K14 manifold? (3 Replies)
- The B***dy downpipe nuts (10 Replies)
- Radiator bleed screw/ tap vanished, possible better solution (4 Replies)
- Cambelt changed 25k, 11 years ago - does it need changing? (7 Replies)
- Squeezing more power out of an already maxed out 11mm bosch pump (28 Replies)
- Washer bottle (3 Replies)
- Need the help of you Internet Diagnostic gurus (10 Replies)
- Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? (4 Replies)
- T3-t4 turbo (6 Replies)
- Problem turbo pressure gt2056s (6 Replies)
- Car running hot (4 Replies)
- lb/ft max gt2056s (0 Replies)
- NA to Turbo - now needs more heat (14 Replies)
- Timing / Pump Issue (6 Replies)
- Turbo relocation (9 Replies)
- Using an alternator from a petrol? (3 Replies)
