XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- Bosch pump conversion (14 Replies)
- Hot idle very high (5 Replies)
- £17.99 for 20l veg oil in Costco (1 Reply)
- flywheel stuck (14 Replies)
- Bit of advice needed in the name of reliability! (19 Replies)
- 306 drift action (10 Replies)
- Injectors (3 Replies)
- VNT control (36 Replies)
- k14 turbo noise (16 Replies)
- Dropping off boost :( help please (7 Replies)
- Inlet stud help (10 Replies)
- Head gasket change (19 Replies)
- 4 Speed ZX? (7 Replies)
- Bens bosch conversion dont use the wrong key! (236 Replies)
- Oil leaking (4 Replies)
- Noisy glow plug relay (5 Replies)
- FML - engine/cabin smoking (50 Replies)
- Changing injectors...help (11 Replies)
- headgasket - changed! (6 Replies)
- T25 wastegate actuator spring (7 Replies)
- I has a leaky ... Injector (20 Replies)
- MBC on a K14? (11 Replies)
- Gear selector rod bush (4 Replies)
- hot start problems - but will bump (5 Replies)
- New clutch needed (7 Replies)
