XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- intercooler gasket (8 Replies)
- xud head on hdi block .is it possible??? (13 Replies)
- Tdc/ crank sensor part number (4 Replies)
- Fitting hdi rods?? (38 Replies)
- Ph1 xud in to ph3 hdi shell (17 Replies)
- Bending throttle arm for more travel (12 Replies)
- oil catch tank (12 Replies)
- lda hat removal (screws nit torx issue) (7 Replies)
- quick boost gauge question (5 Replies)
- Power steering removal.. What belt to run? (14 Replies)
- Upcoming headgasket change (8 Replies)
- Bosch pump semi ecu (6 Replies)
- Expansion tank clip (3 Replies)
- air filter (2 Replies)
- Umm...slightly epic fail involving rag and inlet manifold... (3 Replies)
- veg perished pump causing stalling? (15 Replies)
- Lucas fuel screw (2 Replies)
- Intercooler seal (5 Replies)
- running a filter with xantia manifold? (18 Replies)
- Manual Boost Controller and wastegate adjustment (18 Replies)
- smoking question (6 Replies)
- Crap in fuel tank (2 Replies)
- gear box mount (0 Replies)
- Decent MBC's? (1 Reply)
- White smoke on start up (8 Replies)
