XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- I think its an 'oh dear' moment..... (9 Replies)
- Fitting bigger turbo shortly (16 Replies)
- xud seals etc (2 Replies)
- VE pump cracked...thoughts? (3 Replies)
- Engine problem peugeot 306 diesel (6 Replies)
- engine rebuild questions (1 Reply)
- Max fuel screw (11 Replies)
- Sorry v. newbie Q: difference between TD engines (4 Replies)
- Cleaning xud injectors. (6 Replies)
- Broken heater matrix pipes (6 Replies)
- Low fuel cause bad knock (1 Reply)
- Hard to start (17 Replies)
- Crank pulleys for 2.1 (5 Replies)
- Light blue smoke (5 Replies)
- ECU help (4 Replies)
- 1.9d turbo 306 engine swap to a berlingo (7 Replies)
- Xud9te engine (2 Replies)
- Is this the correct CG clutch???? (7 Replies)
- Running Tempature (10 Replies)
- swapping 1.9d to xud? (0 Replies)
- Twin turbo high pressure oil feed setup. (17 Replies)
- Cheap Chinese Pump Heads , any good? (16 Replies)
- XUD Oil Change - how much oil? (21 Replies)
- Forged HDI rods?? (35 Replies)
- MLS headgasket enquiries. (14 Replies)
