XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- Xud engine code/ internal parts needed (4 Replies)
- Bosch pump experts needed! (8 Replies)
- tdo4 on xud (2 Replies)
- Piston Rings (5 Replies)
- TD04 (2 Replies)
- Turbo (3 Replies)
- Head head head studs ??? (1 Reply)
- Initial issues ????? (2 Replies)
- BIG POWER!! WHAT YOU RUNNING? (7 Replies)
- Misfire at idle (6 Replies)
- Gti6 flywheel on a xud. Will it work? (14 Replies)
- Best Rad for Dturbo? (10 Replies)
- Correct type of thermostat? (1 Reply)
- xud9 doesnt like the red ? (3 Replies)
- Filter housing replacement (2 Replies)
- XUD timing belt kit compatibility (4 Replies)
- Help sourcing gaskets... (6 Replies)
- Max Piston Protrusion / Notches (2 Replies)
- Car broke down on way to work this morning. Gearbox issue. (2 Replies)
- Bigger turbo suggestions? Something handy found? (8 Replies)
- Forged Xud vs M-HDI (15 Replies)
- Bosch injectors (12 Replies)
- oil out of breather under hard cornering (9 Replies)
- Is thickness of radiator important? (10 Replies)
- Sump (7 Replies)
