XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- How do you remove old injector washers? (16 Replies)
- Which injectors? (0 Replies)
- Oil temp (2 Replies)
- actuator (9 Replies)
- Turbo talk (43 Replies)
- T2 Safe Running Psi? (16 Replies)
- AUX belt (2 Replies)
- Early non-cat downpipe ID (15 Replies)
- What Temperature? (13 Replies)
- Which oil pump should I use? (3 Replies)
- Straight through exhaust/mot regs (71 Replies)
- Rebuilt bosch, problem? (6 Replies)
- FMIC pipe routing (30 Replies)
- Stagnent water in the head and bores (8 Replies)
- air in fuel hard to start when cold (12 Replies)
- 1.9td fuel pump (6 Replies)
- Snapped my Cam shaft. :( (20 Replies)
- which fuel filter ? (10 Replies)
- throttle shaft leaking fuel (7 Replies)
- Question time.... (24 Replies)
- d turbo s smokey on start (3 Replies)
- pre-heat led random (4 Replies)
- which alternator belt (4 Replies)
- Forging a bottom end what's involved (7 Replies)
- limited boost out of t25 (22 Replies)
