XUD Section
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
Threads
- Cannot get boost past 15 psi?? (5 Replies)
- Glow plugs (13 Replies)
- xud help (18 Replies)
- Peak boost (13 Replies)
- veg?? (6 Replies)
- Panel Filter or Induction kit and exhaust system? (10 Replies)
- Refurbing injectors (10 Replies)
- fuel pipe to pump (2 Replies)
- what timing belt to get (13 Replies)
- xud rocker cover gasket (3 Replies)
- Turbo Change (3 Replies)
- 11mm pump conversion completed running and has now broke down!!! HELP!! (9 Replies)
- D turbo losing water (11 Replies)
- Hunting, whiteish smoke on idle, diesel knock.. (17 Replies)
- Engine swap issues - Fan help required! (16 Replies)
- sump and HG block face (26 Replies)
- 306 XRDT tailgate quistion? (7 Replies)
- URGENT:cylinder head removal (16 Replies)
- New big end bearings (5 Replies)
- 306 1.9TD AUX BELT PROBLEM (3 Replies)
- not actually running a little hot (faulty temp sender) (12 Replies)
- Flywheel has two timing holes? (14 Replies)
- is this the shitty wastegate on the K14 at fault? (25 Replies)
- MORE problems (8 Replies)
- URGENT! Radiator Change (6 Replies)
