Full Version: How To - 2.1TD Swap / XUD11 Fitting
Pages: 1 2 3 4
I know alot of people here are dead interested in this and hopefully itll be useful for a few people. If this is useful for you will you please consider donating to the club as we run purely on donations not advertising revenue unlike other forums.
So why would you want one?
Well its a nice lazy torquey long stroke motor. It will make an excellent cruiser/daily/tow car but itll never be the 6-7k screaming diesel that some people love from the XUD9s.
On a 9mm pump and standard turbo im running about 150bhp and 240lb/ft and several serial 306 owners agree on that so it cant be far wrong. It dosent feel fast ever but it adds speed at a substantial rate and has a pretty constant rate of acceleration all the way through the revs. Its power band is from 1700-4500rpm and id say its comfortably above 110bhp and 190lb/ft all the way through that range. It never feels troubles of frantic when you put your foot down. I think its more comfortable driven slowly than the XUD9 too. Loves sitting at 2k on the motorway at 60mph and does over 60mpg at that speed too (and on veg at 90ppl makes for seriously cheap running)
So this is my way of doing it keeping the turbo in its standard position, not gearbox mounting it as that requires some custom fabrication. Theres other ways of doing things im sure but im only gonna write about what Ive done.
Firstly theres 2 turbo set ups on the 2.1 Lumps, the XM/605 lump that puts the turbo on top of the manifold and the 406/Xantia lump that mounts it straight out the back of the manifold however from what i can see both appear to be in pretty much exactly the same place and both have the hotside on the drivers side of the car so have to route their outlet elbow under the turbo to get anywhere near the exhaust tunnel.
So where to start.....
Essentially the lump drops straight in on standard mounts with a standard 306 flywheel, clutch and gearbox. Its the details thatll get you.
So
The engine itself is taller for the longer stroke and also the head is bigger for the 12valves and with the inlet running over the top of the engine this makes it a very tall lump, the top of the manifold sits about 10-20mm higher than the being level with the top of the wings. I think on a ph1 this would be a big issue, as it is I have a ph3 bonnet with the bulge in it and had about 15-25mm clearance
Youll need to use a 306 Bosch pump set up and injectors but youll have to bend the fuel lines to get them to fit. Use all the 306s standard fuel lines too.
You need to bolt the 306 upper engine mounting arm and 306 bottom engine mount to the XUD11 lump.
A standard 306 gearbox and flywheel bolts straight up but you will need to drill and tap the back of the block for an RPM sensor. Just measure the 306 block across 2 of the fly wheel bolt holes with a straight edge to see how far out you need to drill the new hole.
You use the standard 306 Starter motor
You cant fit the turbo closer to the block in a 306 orientation as it will hit the water manifold at the back of the block that is substantially larger than the 306 one as it houses the thermostat.
The turbo oil return pipe will foul the gear linkage meaning you cant get 2nd, 4th or reverse, trim the rubber at the bottom and unbolt it from the turbo mount then use 2 cable ties round the engine mount to pull it about 20mm towards he driver side.
The 306 water pipe that runs alongside the engine is slightly too small to fit on the water rail but with a bit of washing up liquid and swearing it will go on.
The water pipe that runs vertically from the water manifold fouls the master cylinder, heat it and bend it so it sits between the first 2 runners of the inlet manifold.
The thermostat housing (with the fuel filter housing on top) from the 306 block can be swapped to the XUD11 block as then you keep the 306 sensors and also loose a water hose that would of been unused otherwise.
The thermostat is in the water rail on the XUD11 so you can remove the 306 one or the XUD11 one or leave them both in (as I have).
Use the 306s Alternator and power steering set up and bracket but youll need to grind a bit off the sump to fit the bracket.
The turbo outlet is the main bit that fouls. It sits on the steering column UJ right on the bolted bit and its flange. Youll need to heat the pipe and put a dent in it and also grind down the bolt and the flanges a little. Group N engine mounts will also help solve this issue as its worst under acceleration when the engine rocks backwards.
The other bit the turbo outlet fouls is the drivers foot well at the start of the exhaust tunnel right up high just under the cross member of the bulkhead. Be careful as the heater matrix is just above this and youll need to knock it in towards the pedals by what is probably a good couple of inches.
Youll also need to cut out/flatten with a big hammer a long section of the box section that runs across the back of the bay to stop the turbo hitting it.
Youll need to fit a FMIC as it dosent have the option of a TMIC.
The wastegate is a piece of piss to adjust when its off the car.
Use the 306 wiring loom.
If youve knocked enough out of the exhaust tunnle a peugeot 605 front pipe will bolt straight up (early ones didnt have a cat) and its a good fit in the tunnel.
Youll then need a 3dr TD/HDi center section shortened by about 12 inches (the exact length of the center box if you buy from ECP) but when we cut the box out we found the 2 bits left sleeved inside each other so would be easy to weld (we hammered, sealed and drilled and bolted them together).
We then found the back box didnt meet the center by about 2 inches, we could of bent the hangers but we very carefully cut the hangar off the box and used a f*ck massive jubilee clip to re attach the hangar 2 inches further down the box.
And thats about it. Im not gonna talk you through every pipe but have a good supply of bits of hose and youll do well.
It will need a FMIC but if your gonna do an engine swap you can manage to bodge on a FMIC.
So what youll need and its costings.
Engine - £70-£300 Mine was £250. Itll need to come with water manifold, turbo and upper and lower inlet manifolds, everything else really is best replaced with 306 bits.
FMIC kit - £50-£500 Mine was £180. The inlet manifold is 60mm and the turbo outlet is 54mm OD so a 2.25" kit will just have enough stretch to fit both of those.
Bosch pump lines and injectors - Free-£30-£300 Mine was FREE as it was on the car before hand. The semi ECU pump these have as standard wont like being swapped about You might well want to fit this with a 10mm or 11mm pump as ive already maxed my 9mm pump and im only just hazing on boost.
Gearbox - Free-£100 Mine was £50. You can use a standard DTurbo box (or any BE series box for that matter really) but ive gone for a 306 HDi box as it gives longer ratios that suit this engine better and it does 2000rpm at 60mph on the motorway and at that speed gives over 60mpg.
Exhaust bits - 605 front pipe was £50 and the center section was £25 brand new
Obviously its advisable to do all the service bits when swapping it over plus cam belt, water pump and a clutch and thatll add another £300 to your total.
If you want to do it KrisB french car specialist did mine with me getting in the way alot he can be contacted www.krisb.co.uk and I reckon he'd want all the parts and 2 days labor to do it, maybe a little more as just swapping so much stuff over is time consuming although none of it is particularly difficult.
Are there supposed to be pictures?
I have plenty to add if anyone wants to know.
Bosch pump - you need a lucas injector line, it's Number 2 if counting from gearbox end. If using bosch bracket it'll also need some removing as it doesnt sit flush because of engine mount.
Turbo - fouls on steering as mentioned. Pig to get working properly. Needs 1cm dent in the outlet pipe to clear steering universal joint. Thankfully the outlet is steel and not cast, so techically it would be very easy to weld some onto to get the correct exhaust positioning, thus not having to smash ten bells out of the bulkhead and not having to buy a different downpipe.
RPM sensor. In the middle of the flywheel, there's a round protrusion (not the little lug), from the outer edge of this measure 106mm outwards to a suitable flat area at the back of the block. Drill to 16mm and insert sensor. Dumdums is holding itself in.
Sump, Grind off both round bits on the cambelt side. Also grind off upper left aircon mounting.
Coolant pipes, original 1.9 matrix hoses onto port on RHS of head and the pipe you have to bend that fouls the master cylinder. Cut down to length.
To plumb in oil cooler you'll need an additional waterpipe from oil warmer/cooler round to the open port on the waterpump.
Basically, just use as much 1.9 stuff as you can to make life easier when shoehorning into a 306.
Dont forget to take out the bit of nylon in the crank (flywheel end) before the box goes on.
Use 2.1 aux pulley.
Dont forget to add diesel, not veg on freezing days.
brilliant
Your a ledge for writing this up. who knows it might come in useful for me oneday...
Good write up chaps!
So have you scrapped it yet Dum? /Troll lol
Looks like it goes very well, pulls very consistently
hi chap...
did you block off the egr??
I am intending too, just curious if you found a good way to plug the back of the plastic manifold...
[Image: 20121206_160853.jpg]
Chemichal Metal (hard and fast) you can get it from halfrauds by the glues. I wrapped about a third of a tube into a roll then wrapped it round a little plastic pipe joiner (for boost take off) and stuck it in. Once it had hardened i packed another 1/3 of a tube in each side totally seal it.
very good guide Dum-Dum a question though does this effect your insurance much? as its a different engine size/mod also what cars have the 2.1 engines fitted? so can look in local scrap yards etc
(06-12-2012, 06:29 PM)Dum-Dum Wrote: [ -> ]Chemichal Metal (hard and fast) you can get it from halfrauds by the glues. I wrapped about a third of a tube into a roll then wrapped it round a little plastic pipe joiner (for boost take off) and stuck it in. Once it had hardened i packed another 1/3 of a tube in each side totally seal it.
lol quickie as it goes!
Good call though on the boost take off...may find a neat way of doing it from there...hmmm
(06-12-2012, 07:24 PM)vincent1 Wrote: [ -> ]very good guide Dum-Dum a question though does this effect your insurance much? as its a different engine size/mod also what cars have the 2.1 engines fitted? so can look in local scrap yards etc
the xud11 was in the peugeot 605 and citroen xm, maybe others, but basically in cars that are quite rare in the UK, most of them stayed in france
(08-12-2012, 04:04 PM)ozonehostile Wrote: [ -> ]
cheers for that will look about to see what i can find.
Came in Xantias and 406s too....
did you still go under engine with turbo pipe as per original 2.1?
(08-12-2012, 04:04 PM)ozonehostile Wrote: [ -> ]the xud11 was in the peugeot 605 and citroen xm,
and the 406, the xantia, that 806, the synergy the fiat people carrier of the same shape and a load of other stuff (not to be confused with the renault 2.1 though)
(08-12-2012, 10:44 PM)Piggy1987 Wrote: [ -> ]did you still go under engine with turbo pipe as per original 2.1?
None of my turbo pipes ever went under the engine. Ive got an XM lump which had differences compared to your (IIRC) 406 lump look at the differences on service box
sorry to be dum (no pun intended) but...service box??
yeah mines the 406 lump
Service box is the Peugeot parts computer and unusually for a major manufacturer the public can get free access.
You can either register yourself or we have club log in details somewhere if you look in the guides section. I have access and ive got my "X number" linked with my local dealer so i can order parts at the click of the mouse
(09-12-2012, 03:15 PM)Dum-Dum Wrote: [ -> ]Service box is the Peugeot parts computer and unusually for a major manufacturer the public can get free access.
And you did that how?
(09-12-2012, 03:31 PM)Niall Wrote: [ -> ]And you did that how?
You need a traders service box, not the free one (dont worry it dosent cost anything) then you go down to the local dealer and ask if theyll do it for you.
yeah just realised how to do it. you never used to be able to do that! might drop the parts store a email in a bit!
your turbo must have a different outlet as mine points down and under the sump!!
Nice write up, couldn't have done it better myself,
I should mention something though that gave me a bit of bother....
Dum-Dum mentioned something about the Thermostat on the back of the block, this is a completely different setup to the 1.9 and the engine I bought (2.1) had most of it missing, mainly the top part of it, I went to a Peugeot dealer to see if I could buy one, I could, sort of... they would only sell me the complete assembly as it was all machined together to match up, and it's cost.........
£200!!!???!?!?!?!?!!???
f*ck that....
I even rang around local scrap yards, they didn't have what I wanted and the guy that I bought the engine off was willing to send me the missing part, so I had to make my own, it works fine and doesn't leak but it's a hassle that I shouldn't have had to deal with,
So when buying your engine make sure it has this on it and everything else that you need for the job,
Also just to note, I've had no problems with the revablity of this engine over the 1.9, they seem about the same really.... I would have another 2.1 over a 1.9 any day Smile
mine came with that housing...its a work of art...i took pics and posted them in me thread!!!
how did u ge those fugures what have u done to it
the pump has been gov modded, fuel wound out to the point where the revs start to hang then wound back in a tiny bit, throttle arm bent for more travel, proper hot and cold idle adjustment and now an lda grind and spring tension changed
How many reliable horses with suitable turbo and pump could be squeezed out of that engine?
Dont know how I havent seen this before,
But nice one Chris for taking the time, really usefull lump of information for people!
just to add....
you will need to use the xud9 pump cradle if you want to use the xud9 aux setup. the aux tensioner may well need a little grind too.
and be prepared to bend the injector pipes quite a lot, and use a combo of bosch/lucas ones to make it all fit.
No one is sure of what power to expect from a standard engine sand turbo, I have yet to get it on the rollers to see
Pages: 1 2 3 4
