XUD RR results *THE BIBLE*
  • 2 Vote(s) - 3.5 Average
(22-09-2015, 01:03 PM)ADV_93 Wrote: GT2056S @ 38 psi, TMIC, 11mm, WMI - 186 bhp/298 lb/ft
Turbo lasted until day after run but thought it was impressive
Prob would have made good/same power at lower boost and saved the turbo
^^^was what I was thinking tbh
It had a welded Westgate on it, it was you old turbo piggy that I had then sold atlas
Sorry, a welded WG on a GT20?! lol
Did we not learn ages ago that this is a bad idea?
Haha!
Yeah, recall the lad with the zombie 306 who first tried a GT2056 iirc with a solid wastegate and promptly spat the turbo out the exhaust!
C S Pellow iirc Smile
Epic little turbos. Shame theyre made of cheese
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
If they're kept at a sensible boost level, they'll last.. what did you expect at nearly 40 psi lol
(23-09-2015, 11:35 AM)Midnightclub Wrote: If they're kept at a sensible boost level, they'll last.. what did you expect at nearly 40 psi lol
Amen
Soz forum
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Meh, it's your loss. Just seems kind of pointless when it'd still be running and making the same power if you'd done it properly.
(23-09-2015, 06:00 PM)Jonny81191 Wrote: Meh, it's your loss. Just seems kind of pointless when it'd still be running and making the same power if you'd done it properly.
Hmmm.
Was thinking that with a fmic and at say 27/28psi you wouldnt need the WMI to bring temps down at all either.
Good effort though lad! Just its not a honest figure in my book as you can only make that figure with that setup once or twice before it will crap itself
Cleaned, please keep on topic chaps, feel free to abuse each other on FB Big Grin
Hello everyone
you feel how the power of my car
https://www.youtube.com/watch?v=VkUCkQME5gk
I'll add mine, from the 205 derv missile.
176.7hp, 247lb/ft - GT2056s @ 23/24psi, FMIC, 9mm Gov and LDA , 2.5" downpipe and exhaust, lightened flywheel, ported head, hdi rods, ARPs.
(05-01-2016, 05:29 PM)niciou Wrote: Hello everyone
passage au banc :
205 td 2.1 8 s , turbo td04l 15t , 30 psi
puissance : 229.4 cv a 4417 tr/min
couple      : 431. NM
passage au banc :
couple      : 431. NM
test puissance en video:
https://www.youtube.com/watch?v=XmHHOHt3...e=youtu.be
https://www.youtube.com/watch?v=W0aciRaw...e=youtu.be
passage au banc :
couple      : 431. NM
Hi everybody
Passage to the bench
ZX td
Turbo t2-t25 pressure 1.6 bar
Fmic
HDI box
Pump 11mm
169 cv
326 N-M
(21-01-2017, 01:40 PM)niciou Wrote: Salut a tous
passage au banc  zx td
pompe 11 mm
turbo t2-t25
intercooler frontal
boite hdi
pompe 11 mm
turbo t2-t25
intercooler frontal
boite hdi
What power did it make then??
pompe 11 mm
turbo t2-t25
intercooler frontal
boite hdi
pompe 11 mm
turbo t2-t25
intercooler frontal
boite hdi
 Sorry i try to put the sheet of the passage to the bench i can not get thereUndecided
169 cv
326 N-M
Not a bad result that for an old turbo which is essentially bolt on job
(21-01-2017, 01:40 PM)niciou Wrote: Hi everybody
ZX td
Fmic
HDI box
Pump 11mm
169 cv
326 N-M
Thread tidied up. Tom (zx_volcane) is right. Thread is for rr figures.
1.9 xud
Td04 & 11mm pump. Harsh lda grind
35+ psi
Smile
(21-10-2017, 04:38 PM)Paul_13 Wrote: 1.9 xud
35+ psi
Smile
boom!
In many ways
Good result man. Must go like a rocket in that thing
A great result, just hoping it lasts. Mine did 170 horse at a safe 20 psi. Don't really want to risk much more boost on mine as it's fast with 20 psi. Yours must be a right monster. Well done.
first try at 2.5 bar
loose clutch
Thanks given by: Martin306
Hoping to add our 206DT to this list soon, got to sort a cooling fan and book in with a local company but I'm expecting (hoping for) 160+bhp from butt-dyno measurements from-:
Square-port D8A stock Xantia engine mileage unknown,
K14 @ 25psi,
Xantia FMIC,
Mix of Xantia and home fabricated hard pipes,
Open turbo elbow currently but may go to 2.25" straight pipe,
9mm Bosch gov'd and LDA ground 'til I got scared it'd snap,
206 GTi180 flywheel,
Running 100% Sunflower oil
Will report back when I actually have paperwork, even if it's embarrassing as feck!
EDIT- well I spoke too soon, K14 is dead, oversped the feck out of it (27psi-ish @ about 4700rpm with small boost leak from intake mani') and blew the turbine apart!  Soon to be replaced with a GT2052V along with better manifold sealing.  Hopefully be a better match for the kind of power we're after & if I get the VNT actuation just right should be a bit easier on the standard head bolts.
  Dyno Results inside! (and questions) Jimbo 30 19,962 13-06-2014, 10:22 AM
Last Post: zx_volcane
  My dyno results Mac22 8 5,409 12-06-2014, 03:26 PM
Last Post: Mac22
  Bosch, T2, stage one, dyno results? Mitch 22 20,963 14-04-2013, 08:36 AM
Last Post: Mitch
