Threads: 151
14
Car Model/Spec: 306 D-turbo
Sounds like a air leak mate spray some carb cleaner or something allong them lines where the gaskets are are if the revs pick up that's where the leak is
Team Doesn't own a 306
Threads: 183
20
I bought one other day actually.
So whole point of getting car running nicely is to see if it gets to temp and not over heat during mot...
Assume that hose popped out of the rad?
The way the hose is fixed into the rad is shite really!
The idle will be a air leak somewhere or a very very sticky ICV although even if the plunger was fully open, i don't think it would rev up to 3k. Also check your TPS.
