Threads: 92
5
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Given 3 thank(s) in 3 post(s)
right iv changed the waterpump and cambelt in the car, locked of straight forward no problems, once fitted i turned over by hand 3 times with no problems, fitted the starter went to start nothing, thought ok chuck on another starter, nothing seemed like the fly wouldnt go (if you know what i mean)
jacked it back up, removed starter, put in fifth and started turning the drivers wheel turns a lil but then stops as if something is stopping it
iv removed the inspection plate underneath and cant see anything so now im a bit stumped.
Any ideas???
thanks dan.
Current cars
Subaru Impreza 2.0d - Daily
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Given 1 thank(s) in 1 post(s)
Sure you removed all the bits from locking it off?
Threads: 92
5
Yep double, triple checked
Current cars
Threads: 206
3
Car Model/Spec: 3dr dt-s
Given 0 thank(s) in 0 post(s)
PANIC !!! dont ever turn an engine over an odd number of times---only 2,4,.......
reason is if you do an odd count then cam will be half a turn out, which does lead to people then removing belts/pins/devices to shift everything again which will result in tears when you try to start it ??
allways even number of times to check/recheck the belt and timing marks.
Threads: 581
195
I always turn mine over 4x at the crank which if I'm correct, is 1 full rotation of the belt, then refit pins to make sure everything is still lined up.
Threads: 92
5
right iv come the the conclusion i may be hitting the valves
how can i retime the cam if it wont allow me to turn the crank?
Current cars
Threads: 90
54
You said it turned over THREE times though fine?
If the motor turned over three times 10 seconds before, you cant be hitting valves....
Threads: 92
5
So what do you suggest then? Im jus trying to solve it lol
Reading that back it sounds patronising but its not lol
Current cars
Threads: 91
12
Car Model/Spec: 306 D Turbo
Its nothing silly like being left in gear, otherwise it does sound timing related. Have you rechecked the pins yet?
Threads: 92
5
The pins arent lining up now, the cam and pump dnt line up wen the fly is locked, there 180 degrees out, problem is with the without a pin in the fly i stil cant turn it enough to lock off the cam, can i manual set the cam up?
Current cars
Threads: 92
43
Car Model/Spec: Tracterrrrrrrrr
Given 2 thank(s) in 2 post(s)
Take the belt off and then lock everything off again
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
Threads: 92
5
How would i lock the cam off with no belt? Use the 17mm nut?
Current cars
Threads: 92
43
Yeah just rotate the cam shaft and pump and put the bolts in
