	Threads: 43
0 Location: cambridgeshire
 Car Model/Spec: 2.0 hdi
 Thanks: 2Given 0 thank(s) in 0 post(s)
		hi guys im just starting to learn general mechanics and iv just fitted new suspension and brakes but I wasn't very confident in bleeding them up so got a local garage to come out and bleed them now they feel worse than when I attempted
	Threads: 371
29 Location: suffolk
 Car Model/Spec: ford fiesta
   Thanks: 4Given 82 thank(s) in 82 post(s)
		Get them to come out again then and complain. What brakes did you fit. Are you sure you fitted them correctly
On a break from 306oc for personal reasons. If anyone needs or wants me most of you have my number and or facebook messengerThanks for the good times guys n gals. I might be back. Who knows.
	Threads: 43
		I have im waiting again, should they all bled all 4 brakes or just just front as the caliper was disconnected
	Threads: 57
3 Location: Peterborough
 Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
 Thanks: 1Given 3 thank(s) in 3 post(s)
		If you had a caliper disconnectd you want to get all four bled
 What method did they use to bleed ?
	Threads: 43
		they just made me pump the brake then let off while he did the nipple up
	Threads: 371
		If you drained the brake fluid. All four nees doing. If you locked the line off you only need to bleed one.
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		You need to do all 4. It'll probably take at least half a bottle of fluid to bleed properly. You need to do then in the right order too. I believe its NSR OSR OSF NSF
	Threads: 45
0 Location: Ludlow, Shropshire
 Car Model/Spec: HDi DTurbo 2001(Y) Astor
 Thanks: 0Given 1 thank(s) in 1 post(s)
		As Sam said ^ bleed all brakes to be safe from closest caliper to the furthest from the mbc.
Team disASTOR?
	Threads: 11
0 Location: Stockholm, Sweden
 Car Model/Spec: 306 GTI-6 trackday toy
 Thanks: 0Given 2 thank(s) in 2 post(s)
		There is a risk of damaging the master cylinder piston seal when you bleed brakes on old cars with that technique, rust inside the cylinder bore can scratch the seal. During normal use you never manage to push the pedal all the way down but when bleeding you do.
 Is your pedal spongy or does it sink slowly to the floor? Or do the brakes just not bite?
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
	Threads: 55
17 Location: Rotherham
 Car Model/Spec: 406 V6
 Thanks: 3Given 10 thank(s) in 10 post(s)
		It's not rust (or shouldn't be unless there's water been in there), it's the fact that there'll be a wear lip that the seal goes over after years of use.
Custom roll cages/shiny suspension bits/general fabrication work undertaken, PM me.Top engine mount repair/reinforcement/chocking for cracked chassis and high powered cars, drive in, drive out, 2 hour turnaround.
	Threads: 43
		pedal just feels soft and you have to push pedal to floor for it to brake
	Threads: 266
18 Location: Somerset
 Car Model/Spec: 205 DTurbo
 Thanks: 73Given 7 thank(s) in 7 post(s)
		If you've fitted brand new pads/discs they'll take a few miles to bed in.
	Threads: 177
3 Location: Highlands, Scotland
		14-11-2014, 06:54 PM
(This post was last modified: 14-11-2014, 06:54 PM by Daniel306.)
		it wont got tho floor tho, they need bleeding again
	Threads: 145
5 Thanks: 54Given 18 thank(s) in 17 post(s)
		15-11-2014, 10:54 AM
(This post was last modified: 15-11-2014, 11:07 AM by pug306driver.)
		brake fluid absorbs water from the atmosphere ( does modern dot 5 stuff do that as well???? ) etc........
 gravity ( with m/c cap off ) could be used for a very basic bleed, when fluid and no air emerges from the nipple then its time to bleed properly......
 get an assistant that will do exactly as you say as you will be the one in "command" at the nipple.
 follow the procedure for which nipple to bleed first etc...........
 with all nipples showing air free fluid flow via gravity method, and with all nipples closed, start at the nipple furthest away from the m/c.......
 get the assistant to "pump up" the brakes with say five firm presses of the pedal ( the "pump up command" ) in quick succession with them taking the foot off the pedal each time so the system can pressurize and fill etc........then press the pedal ( the down command ) down and keep pressing ( not over the top and trying to burst a pipe etc ) which is the "down command"......then the assistant says "down".........so you know what they are doing!!......at this point open the nipple gently and watch the fluid emerge from the nipple, go thru a clear plastic pipe and into a 1/4 filled jam jar or similar of fluid.........
 the assistant will notice the pedal go down to the floor.......he must keep it there while you nip up that nipple.
 you say the "up" command and the ass complies......wait for the m/c to take a new mouthful of fluid and repeat process.
 take you time and communicate with each other else you will have to start again. remember you are in command.
 did the fluid level in the m/c res  rise when you pushed the caliper pistons in?? and where they stiff or go back in with thumb ( if not heavy ) pressure with the res cap off??
 there is a very small ( tiny ) hole in the m/c bores to the res for "recouperation" or return of fluid when the brakes are released or get hot etc.....else they with drag and possible not release at all!!  if that is blocked.  if it is blocked then bleeding can be problematic.
 ps never let the m/c res fluid level drop too much else you will pump air etc!!!!!!
 pps a syringe full of new clean fluid can be used to "wash" the black crap on the m/c res floor and suck that out, rather than have all that crap be pumped thru the system..........also leave time for an "airation" or tiny tiny air bubbles in the res fluid to rise and pop else you will pump that thru the system as well !!  or buy a pressure bleeder.....and do it single handed.
	Threads: 43
		thanks for that very good description the garage have said theres airs in the rears but there not willing to bleed them incase the rear nipples snap
	Threads: 177
		Tell them its there fault the air is there and to get it sorted
87 Location: Suffolk
		It's not their fault...they didn't change the front one.
 They've got a point tbh, the rears usually snap...
	Threads: 145
		15-11-2014, 11:17 AM
(This post was last modified: 15-11-2014, 11:20 AM by pug306driver.)
		yes, that is a real danger and of course would be the garages fault as its their car!?
 so, soak in penetrant and leave ( go prey for an hour ), come back and try to release the nipples with out them shearing off!
 hot air may help.........if they shear off, use mig method, drilling as a last resort!!!!!!
 mig method:
 remove caliper from car and mount steady in vice, clean sheared off remains as best as possible and weld a blob to the sheared nipple in caliper, allow to cool and repeat. be care full not to weld the nipple remains to the caliper!!!!!!!!!
 when blobs are big enough ( say 3 blobs ) weld a prepared bolt ( suitable sized bolt with a tapered end ) to the blob, and gently try and release......if it shears off try again.
 ok, a different way......remove pads and pump out piston as much as you dare, clamp hose and undo a union a bit and push piston back in, repeat till no air comes out.
	Threads: 177
		15-11-2014, 11:35 AM
(This post was last modified: 15-11-2014, 11:36 AM by Daniel306.)
		I normaly weld a M12 or M16 Nut to them in place, but try roasting the nipple with gas if it is not already snapped
	Threads: 110
20 Location: Devon
       Thanks: 1Given 30 thank(s) in 30 post(s)
		Just bleed the rears off the brake pipe if the nipples do snap. But give the nipples a few taps with a hammer and then try them
		 (15-11-2014, 02:27 PM)Frosty Wrote:  Just bleed the rears off the brake pipe if the nipples do snap. But give the nipples a few taps with a hammer and then try them
This is what the garage did when I snapped one of mine (well Rowells lol    ).  Seemed to work just as well but didn't trust myself doing it that way lol.
	Threads: 110
20 Location: Devon
		It's not to bad doing it off the brake pipe. It just requires 2 people ideally and does tend to make a mess with fluid going everywhere. I've had to do it a few times with the reputation of the nipples snapping off on 306 rear calipers
	Threads: 92
43 Location: Brizzle
 Thanks: 2Given 2 thank(s) in 2 post(s)
		 (15-11-2014, 08:13 PM)Frosty Wrote:  It's not to bad doing it off the brake pipe. It just requires 2 people ideally and does tend to make a mess with fluid going everywhere. I've had to do it a few times with the reputation of the nipples snapping off on 306 rear calipers
Best way to avoid snapping nipples? Dont work on 306s    its what I try to do as much as possible, havent snapped a nipple yet    although when I put new front discs and pads on mine, i though id flush the brake fluid through and one of the rears felt like it was gonna snap, so didnt do that one lol
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam22:57: SRowell - :wtf why didnt you try harder to make me come!
 ![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
