Andyyy's 1.9 DT 205 Cherry Red VNT
Hasn't been much progress lately as iv been very busy with my job and my daily has been giving me endless issues but I'm now not too busy for a while and the daily has been fixed and passed its test so things will hopefully get moving again
Only update for now is iv fitted a high flow thermostat (came all the way from australia )
So that should help with cooling
[Image: IMG_20140818_174256928_zpsffzp2aht.jpg]
[Image: IMG_20140818_174537789_zpslh90bp2f.jpg]
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
#32
Have you got a link for the thermostat??
#33
Doesnt look any different Undecided
Pugracing sells the thread you need for the oil filter
#35
Yeah I'm not sure if it's any good tbh but I needed one anyway and saw that so went for it 30℅ more flow should help better than a lower temp one in theory if it does show any actual gains I don't know yet
Got mine on eBay - a lot more than the cheepest ones but same sorta price pug want for one
http://pages.ebay.com/link/?nav=item.vie...21&alt=web
(18-08-2014, 08:40 PM)Paul_13 Wrote: Pugracing sells the thread you need for the oil filter
Thanks I'll have a look into it Smile
#36
Looking very nice your built up
#37
Thanks
Still loads to do and waiting on lots of parts
Clutch arrived today which made me realise that I don't have the bolts that hold the clutch to the fly wheel so will need to source some
Iv still got to get / do
new gearbox as the old one was shagged before the old engine gave up
Weld the exhaust manifold up (waiting on the pipe hopefully this week)
Get some injectors as the old engine went " missing "
Tidy up the loom
Fit the stdt dial wire them up
Get a radiator and another slimline fan
Sort out the interior which is now a mess
Sand and polish the car haven't touched the car since the respray and the filler sunk so that needs sorting too
Weld up the rest of the exhaust - completely stait through no back box
I'm going to lower the temp the fans kick in but that's all worked out just need parts
The old battery decided that it would leak all of its acid out the other day so replacing that
Finish smoothing and painting the exterior trim
And of course fit it all
Probably plenty iv missed so still plenty to keep me busy
Anyway I got a Sachs clutch as they haven't let me down in the past so hoping that it will hold up to the new turbo
[Image: IMG_20140819_091821817_zpsnltmizwz.jpg]
[Image: IMG_20140819_091829859_zpsn1kitjf9.jpg]
#38
Use a set of sump bolts mate. M7 thread. Got a few if needs be.
I've got a gti dash loom as well if that's of any use.
#39
(20-08-2014, 12:19 PM)Paul_13 Wrote: Use a set of sump bolts mate. M7 thread. Got a few if needs be.
Didn't realise sump bolts were the same cheers for that ! I think iv got some knocking about
I dunno about the loom would it get the stdt clocks going ? I think my loom has all the wiring already there obviously cant test any of it at the moment but I can't remember so I'll have to get back to you on that
#40
I had a problem getting my revvs to work, all the wiring was there And i had a brand new sensor and still nothing, narrowed it down to an earth plug by the clocks ill get a pic for you
Current cars
Subaru Impreza 2.0d - Daily
#41
You have Base model clocks which are far different to stdt clocks.
The amount of plugs are the same, the pin outs should be as well
#42
Yeah iv got base model clocks fitted in the car and iv got some stdt clocks to go in it I heard people have issues with the rev counter so was going to wire it in from the sensor my self just need to find a diagram to figure out how as all the rest should be plug and play I think
#43
The actual plugs on the back of the loom for Base model clocks aren't compatible with the stdt clocks.
I've just done the same conversion myself a few weeks back.
I've been messing around with 205's for bloody ages, if you need any bits or advice just ask. Got loads of parts lying about
#44
looking good there andyyy
#45
(21-08-2014, 04:31 AM)Paul_13 Wrote: The actual plugs on the back of the loom for Base model clocks aren't compatible with the stdt clocks.
Okay I'll give you a shout if I need any thing thanks Smile did you get my pm about next week ?
Thanks procta
So thought I put some photos up of the stdt clocks as were all talking about them
[Image: IMG_20140821_172206832_zpszgk6hjfi.jpg]
The plug for the rev counter
[Image: IMG_20140821_172225058_zpsf12nbgfx.jpg]
And the plug from the sensor
[Image: IMG_20140821_172148416_zpsljmwh8wq.jpg]
I also have a sensor with a brown plug somewhere which I think is the one that will plug into my loom / was plugged in before
#46
Andy, curious thermostat, and will tell us if you noticed impact on the engine cooling
#47
The plug for the Rev counter is blue, either 3 or 4 wires going to it.
Do you want this gti loom? The plugs will got straight on and you won't need to worry about manually wiring up the Rev counter.
You just need to take the dash out and swap the loom like for like. I'll give you a hand doing if you want.
And like I said the base model loom is completely incompatible with gti/stdt clocks
Got your message mate, that's no problem
#48
Yeah if I notice any difference I'll say I'll probably get a OEM one to swap out and test it against once its all up and running I doubt it will do anything to be honest but I'd like to prove my self wrong lol
Yeah I think I'll need tbh let me know what you want for it Smile
#49
You might have to join but this might be useful mate- www.frenchcarforum.co.uk/forum/viewtopic.php?f=4&t=48341
Smile
#50
Nice I'm sure that'll come in handy
#51
Not much progress again due to other things getting in the way but did manage to tap a hose tail into the manifold for the boost controller
[Image: IMG_20140815_182334854_zpsk9miy13g.jpg]
Might tap another one in to go to the compensator on the pump and the inlet adaptor I'm getting at the end of the week looks like it has one (thanks paul) to go to the boost gauge so should be able to keep it all separate and tidy without any t pieces which will be neater
With any luck at the end of the week I can get the car to the work shop and start sanding cutting and polishing and dropping the engine in
#52
So progress stopped due to massive workload at my work hasnt really got any further strarted mocking up come oil lines but thats about it so this is pretty much paused until the work dies down a bit
On a better note got rid of the beamer i was using as a daily (and made a nice profit Smile ) and got a 405 estade d-turbo dirt cheap
#53
Is it red with white wheels?
#54
(17-09-2014, 03:47 PM)Paul_13 Wrote: Is it red with white wheels?
The estate ? if so yeahh
#55
Manged to get some time today in between things to start sorting out an exhaust
decided that making a whole manifold would take to long and that would be a future addition once the car is done
but i still wanted to gearbox mount the turbo so i set about and this is what i came up with
started off by making the piece going to the turbo
[Image: IMG_20140920_121612100_zpsowd8fc9c.jpg]
Then decided i should work from the engine to the turbo not the other way round
[Image: IMG_20140920_140319802_zpsuhrihg1z.jpg]
Holesaw died Sad so started stitch drilling
[Image: IMG_20140920_144957007_zpsrgqjo2ky.jpg]
Then the drill bit i was using snapped so only got that far with drilling today
so moved on to welding some more pipe up
[Image: IMG_20140920_140253005_zpsmrfzqx6i.jpg]
I know its not massive progress but atleast its some
I now need to get some more drills bits so have given up for today and hopefully get some drill bits tomorrow
#56
Yeah, saw you getting your car washed at Winnersh
Looked tidy!
#57
(20-09-2014, 05:12 PM)Paul_13 Wrote: Yeah, saw you getting your car washed at Winnersh
Looked tidy!
Should of come over man
Thanks was awful when I got it but I'm starting to like it now
Was so bad I cleaned the inside my self 3 times before taking it there would of been too embarrising in and out is still dirtier than how I'd like
#58
Welded this up ...
[Image: IMG_20140928_105136600_zpsnph1rr2g.jpg]
[Image: IMG_20140928_105257638_zpstmiocfs4.jpg]
Dying to get this in the car but can't seem to get it at the workshop for now but its no biggy just makes things slower without the use of a forklift ...
Also this is my daily , I know youv seen it Paul but for others here it is.
[Image: IMG_20140928_112652552_zps5qmsdx0u.jpg]
#59
Car is nearly completely polished now and it's looking gleaming
[Image: IMG_20141229_113649548_HDR_zpsfd8iojwa.jpg]
And I've managed to paint some of the plastics
[Image: IMG_20140706_142156166_HDR_zps0w07bksl.jpg]
[Image: IMG_20140706_124409346_zpsqhe19uaj.jpg]
#60
Looking good Smile
