So the 205 siezed up 70 miles away from home and left me stranded
So promptly ripped the engine out (in a local car park lol) and found out that it was actually a 1.7 DT after being sold as a 1.9 DT
Then decided that whilst it was all apart it needed a respray some random photos need to find some better before and afters as these are all part way through
Got a new engine and stripped it down
Started building it up again with ARP head bolts and hdi rods
Then bought a GT2052 and stripped it replaced the chra and clocked the turbo
Also had the actuator apart so it will run off boost
Started makeing a exhaust manifold
There's loads more pictures of things but seems pretty photo intensive soo I'll leave them out still loads to do so should be plenty of updates
Ooooh what an interesting build on here
Thanks feel free to ask anything on that note not sure what to do about fueling would this warrent a 11mm pump or just a gov modded 9mm ?
Id go 11mm personally...
Shaping up to be a hellish project, good work
Thanks guys
NICE!!! 11mm why go half in when you can go all in
Looks great! Best of luck with it.
Thanks guys will look into getting 11mm pump
Haven't been able to do as much as I'd like today due to my daily causing me some issues and deciding to clean the workshop as it was a state but did manage to clean up and paint the sump and fit the water pump
Looking very promising bud....keen to see this finished!
You ever have a 'chat' with the guy who sold it to you as a 1.9??
(27-07-2014, 06:14 PM)Piggy Wrote: [ -> ]Looking very promising bud....keen to see this finished!
i didnt know they done a 1.7 ??
Actually known as a 1.8td but a xud7 officially
Thanks I'm keen to see it done also !
Yeah I had a chat and he explained that it was actually his brothers car he had it to get running but couldnt and his brother was sold it as a 1.9 also lol I only bought it due to it being dirt cheap and bled the fuel lines and it fired right up like a good un !
So couldn't really get any cash back he also works next door to me and I borrow stuff off him all the time so would make things awkard if I had a go
I was more interested as to how everyone came to believe including me that it was a 1.9 tbh
Yeah your right everyone calls them 1.8s well except me but then I don't get why the 1.7s are called 1.8s and the 1.9s aren't 2l's its the same logic of its nearly one but maybe its just me
Well the 1.9s are 1905cc iirc and the xud7 is something like 1760ish. So does make sense...sort of.
To be fair, its easy to spot the diff between the 1.9/1.7 visually if you know what ya looking at
Ahh I thought the 1.9 was more than that just checked and im wrong and stand corrected lol
Yeah I always thought something was slightly off but I guess I just trusted that he was right other than stamp I don't think I would of known tbh
(27-07-2014, 09:27 PM)Piggy Wrote: [ -> ]Well the 1.9s are 1905cc iirc and the xud7 is something like 1760ish. So does make sense...sort of.
Its rounded up or down which ever is closest, So they are 1.8 and 1.9 :-)
Thats what I explained!?
(27-07-2014, 10:33 PM)Piggy Wrote: [ -> ]Thats what I explained!?
sorry just you wrote 1.7 and 1.9 again, ive never heard of anyone calling them a 1.7 before lol
I know but he is referring to it as a 1.7 so just helping him along...
Plus its often referred to as the 1.7 in older citroens etc on thr continent
(27-07-2014, 11:02 PM)Piggy Wrote: [ -> ]I know but he is referring to it as a 1.7 so just helping him along...
Oh right thats the first time ive heard that :-) learn something new everyday :-)
My XUD workshop manual refers to then as 1.7 as well main reason I do tbh
Anyway no progress today but have found photos of the car the day I bought it
Welcoming interior
Paintwork has some minor scuffs - yea thats me
Passenger side was in a bush for 7 years so held up a bit better
There was some rust holes that have been sorted but no where near as much as I expected guess these old girls hold up pretty well !
Great work so far mate
Reminds me of my project till I binned it off and put money to wedding, will be an epic car when it's done! Keep up the good work
Nice car mate, i had a blue one years ago, cool little car!
Thanks for all the positive replys, glad you all like the car
So today iv put the fuel pump timing belt aux pulley and the alternator on also dug out my old mocal oil cooler from another project and i want to run it on this but need to source a part maybe someone can help?
Anyway piccys
Cleaned up the engine mount first
Timing belt on - soo much easier out of the car
Alternator Pulley etc on - old skool altenator!
Shot from the other side
The problem i have with my oil cooler - help pleaseee
If anyone knows the thread I have a pipe threader and could possibly make one up
Just checked and don't have the right size thread cutter for the pipe threader so unless someone makes these I'll have to get one made up
Get rid of the standard cooler and you might be able to use that fitting?
You need to keep the standard cooler as it helps with warm up time and heat balance ec...Ruan explained it all once
So you need another bolt which has female and male threads to bolt the cooler plate ontop of the current fitted one
(30-07-2014, 06:53 AM)Piggy Wrote: [ -> ]You need to keep the standard cooler as it helps with warm up time and heat balance ec...Ruan explained it all once
On a 306 maybe, but on a 205 when the cooling system is already pretty marginal with a TD engine (especially if it's not running the expensive thicker core TD rad!) it's not exactly ideal using a heat exchanger to dump more heat into the cooling system.
Yes, ideally you'd have a heat exchanger to help bring the oil up to temperature quicker and to stabilise temperatures, but not at the expense of reaching the limit of the cooling system with an engine that's so sensitive to cooling issues.
Not only that, but on a 205 the clearance between the 306 style heat exchanger and radiator isn't great and you normally have to run a short Renault oil filter to give a decent amount of clearance - if you tried adding a take off plate for an oil cooler as well then I don't think you'd manage to fit the oil filter on! Remember the 205 engine bay is considerably shorter at the front than a 306, hence needing to tilt the radiator forward when running GTi-6 engines etc.
Personally, I'd remove the heat exchanger and if you think oil temperature will be an issue then fit a thermostatically controlled oil cooler (which that take off plate doesn't appear to be) to keep the oil temperature sensible without over-cooling or excessively prolonging warm-up time.
I'd like to run both if nothing else there will be more coolant in the system (and oil)
Cooling shouldnt be an issue as I'm ordering this off eBay
Link
It is thermostatic but the plate isn't there is a remote oil filter with a thermostatic part inside it (or so I'm told) so will be running two oil filters
Where would I buy a female to male adaptor tried my local hydrolics place where i get my oil lines and brake lines from and they didn't have anything like it don't think its really there sort of thing
If there still will be cooling issues I'd rather fix them than bodge by removing the oil cooler so maybe I should run a 70c stat if I can find one and make the cooling fans come in sooner ? Say at 80c rather than 90c as before
