Best way to clean boost pipes out?
What to use? Got a few 2nd hand pipes I may well be using but all are covered in oil inside.
Whats the best way to clean them?
Jet wash? Diesel? Brake cleaner?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Id just squirt brake cleaner down them
I've been told petrol is good, that's what I cleaned mine out with.
Sand down the intake!
Just kidding, I'd probably go with brake cleaner, though that may corrode...
your tounge is a good bet Tongue
Carb cleaner is good for boost pipes...it's not cheap though. :/
Semen
306 HDI, soon to be XUD
elbow grease!
More boost!
Go to a garage and ask to use they're degreaser, take cakes/food and it should be ok Wink
[Image: siggy1.jpg]
but seriously... http://www.gunk.com/ ... gunk is some heavy stuff!
ginge191 Wrote:but seriously... http://www.gunk.com/ ... gunk is some heavy stuff!
I second gunk. Magical stuff!
Got some gunk in the garage & brake cleaner failing that. Ty!
S14 Zenki Build
O definatly gunk then run them under the hot water tap. Repeat until clean, dry out and fit!
[Image: Atterz.jpg]
