Best way to clean boost pipes out? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Best way to clean boost pipes out? (/showthread.php?tid=2937) |
Best way to clean boost pipes out? - silverzx - 21-04-2012 What to use? Got a few 2nd hand pipes I may well be using but all are covered in oil inside. Whats the best way to clean them? Jet wash? Diesel? Brake cleaner? Re: Best way to clean boost pipes out? - Connor - 21-04-2012 Id just squirt brake cleaner down them Re: Best way to clean boost pipes out? - bigcheez2k3 - 21-04-2012 I've been told petrol is good, that's what I cleaned mine out with. Re: Best way to clean boost pipes out? - Scott - 21-04-2012 Sand down the intake! Just kidding, I'd probably go with brake cleaner, though that may corrode... Re: Best way to clean boost pipes out? - 4WayDiablo - 21-04-2012 your tounge is a good bet
Re: Best way to clean boost pipes out? - Toms306 - 21-04-2012 Carb cleaner is good for boost pipes...it's not cheap though. :/ Re: Best way to clean boost pipes out? - declantg - 21-04-2012 Semen Re: Best way to clean boost pipes out? - Eeyore - 21-04-2012 elbow grease! Re: Best way to clean boost pipes out? - ginge191 - 21-04-2012 More boost! Re: Best way to clean boost pipes out? - devils_fuel - 21-04-2012 Go to a garage and ask to use they're degreaser, take cakes/food and it should be ok
Re: Best way to clean boost pipes out? - ginge191 - 21-04-2012 but seriously... http://www.gunk.com/ ... gunk is some heavy stuff! Re: Best way to clean boost pipes out? - Niall - 21-04-2012 ginge191 Wrote:but seriously... http://www.gunk.com/ ... gunk is some heavy stuff! I second gunk. Magical stuff! Re: Best way to clean boost pipes out? - silverzx - 21-04-2012 Got some gunk in the garage & brake cleaner failing that. Ty! Re: Best way to clean boost pipes out? - Atterz - 21-04-2012 O definatly gunk then run them under the hot water tap. Repeat until clean, dry out and fit! |
