What to use? Got a few 2nd hand pipes I may well be using but all are covered in oil inside.
Whats the best way to clean them?
Jet wash? Diesel? Brake cleaner?
Id just squirt brake cleaner down them
I've been told petrol is good, that's what I cleaned mine out with.
Sand down the intake!
Just kidding, I'd probably go with brake cleaner, though that may corrode...
your tounge is a good bet
Carb cleaner is good for boost pipes...it's not cheap though. :/
Go to a garage and ask to use they're degreaser, take cakes/food and it should be ok
ginge191 Wrote:but seriously... http://www.gunk.com/ ... gunk is some heavy stuff!
I second gunk. Magical stuff!
Got some gunk in the garage & brake cleaner failing that. Ty!
O definatly gunk then run them under the hot water tap. Repeat until clean, dry out and fit!
