Urgent in Bristol...steel wheel studs or a 15" pug alloy
As above I need ASAP as the tyre from the rear of the car has had a disagreement with the rim...I have a steel spare wheel but only have alloy bolts so they would screw in far enough to hold the rim on!
Or can I borrow a 15" std pug alloy which uses the flat seated studs.
Help urgently as the car is on a jack with 3 wheels!
Delivery of the bolts or rim would be a life saver!
[Image: siggy1.jpg]
Flat faced bolts are alright to put in steelies briefly they have a taper at the top for the steel rim to sit on
These don't but that's not the problem...because my cars a drum model the bolts are too long to go through a thin steel wheel compared to the thick alloy rims, making something knock inside the drum as u turn the wheel on a jack Sad(
I looked for steel wheel bolts as they're shorter but couldnt find any..in the end I got some thick washers fitted between wheel and flat wheel bolt head...a bodge to get me to the tyre place tomorrow Smile
[Image: siggy1.jpg]
Did you sort this mate?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Can't you read? lol
Well we dunno if he made it to the tyre place without it wildly exploding. Tongue
S14 Zenki Build
I do cause I saw him yesterday Tongue
sorry don't get thread notification via the website like you do with opther 306 websites lol
I am a live and have 4 alloys again
[Image: siggy1.jpg]
  Wanted: Lots of 306 parts and c5 steel (alloy wheels) wildoliver 1 1,734 01-05-2019, 12:14 PM
Last Post: Teeharv
  Wanted: 306 5dr with a Bosch... Bristol area Piggy 1 703 13-03-2016, 01:23 PM
Last Post: Frosty
  Wanted: Flat seated wheel bolts - URGENT! WiNgNuTz 13 1,947 21-01-2015, 05:45 PM
Last Post: WiNgNuTz
