Threads: 4
Hi all, I've got a rattling tensioner pulley on my Phase 1 306 dTurboS and I read somewhere that you need to drop the engine to change it out, is this true?
I also read something about doing away with the tensioner and using a 'stretchy' belt is this the way to go?
I really, really don't want to remove engine mounts if I don't have to.
Any advice greatly appreciated.
G.
Doesn't have to be removed from the car, but dropping it off the left hand engine mount would probably make it significantly easier... Just put a jack under the sump, lift slightly, undo the bolts, grab the back of the engine, wiggle, and yank on the mount and it'll come free... You can then drop the engine forwards and down...
With regards to the stretchy belt, I think someone's pulling your leg... There's no such thing...
Threads: 4
Anyone got a an idea what the part number I'm looking for is?
Belt tensioner for a 1996 dturbo
Thanks,
Gordon
