04-04-2014, 01:28 AM
They where working fine then tried it the next day it's didn't work iv checked the connection for the dial and the fuse
Heater blower fault
04-04-2014, 01:35 AM
checked the connection on the blower end? sometimes can become loose/corroded/broken worth double checking. if not its probably a dodgy blower motor and will need replacing. which is an easy enough job just make sure when buying a replacement that you get the right one, ac and non ac are different
04-04-2014, 01:42 AM
(04-04-2014, 01:35 AM)Matt Wrote: checked the connection on the blower end? sometimes can become loose/corroded/broken worth double checking. if not its probably a dodgy blower motor and will need replacing. which is an easy enough job just make sure when buying a replacement that you get the right one, ac and non ac are different we only checked the fuse and heater control side of the wiring connections well have to have a look at the motorside tomorrow because we ran out of time today.
NO SMOKE NO POKE
Heater blower issues | Dturbo john | 5 | 2,656 |
13-03-2018, 01:53 PM Last Post: Toms306 |
Heater Blower Issues | MY95 | 7 | 3,292 |
06-03-2018, 11:22 AM Last Post: Magenta Sunset |
Heater blower problem | Pingaz | 7 | 2,292 |
04-06-2016, 01:19 PM Last Post: Pingaz |
