Couple of Gremlins!
Couple of Gremlins!
Right, to kick things off I've had a couple of occasions where the speedo will dart round to 110mph with the trip counter fully lit-up (as in all 000's) then back off again. Normally I'd say battery past its' best? Although I seem to remember it being all of the gauges before. No battery warning light or any other symptoms.
Next issue is dashboard illumination; ocassionally whilst driving along they will go out...then come back on again. Fiddling with the dimmer switch brings them back on. I reckon it could be the dimmer switch itself? Or at least the wiring to it?
Finally, one which has been p*ssing me off a while now, the coolant level warning light. The coolant level is fine, so the sensor is playing up. Should I get a new one or is it easy to remove and clean up? Do you lose coolant when servicing the sensor?
And now my aux belt is squealing like a pig. I only replaced it 9 months ago!!
[Image: Sig500x130.png]
Did you do the aux belt tensioners as well or just the belt?
Only did the belt on mine and it started squealing not long after
Coolant level is easy to replace. Fairly sure it just twist and pulls out!
(06-02-2014, 11:10 PM)rocker8742 Wrote: Did you do the aux belt tensioners as well or just the belt?
Just the belt mate, tensioner costs more so was left! You reckon that could be the culprit? Easy job? Is this where people replace with a 307 version? If so what is the correct part no.?
Ok Rowell I'll have a look later. May just clean it and check the connection, pug want £50 for a new one and I can't find a pattern part?
It's possible it could be, iirc fooby mentioned it could be that on mine when we were away last year
I've not done anything about mine though just left it so I don't know what people replace them with lol
  Electric gremlins happypug 5 1,806 24-01-2014, 11:40 AM
Last Post: happypug
  How's this for electrical gremlins... samass 17 4,106 30-11-2012, 11:16 AM
Last Post: samass
  Oh Noes! Window Gremlins. Help ASAP D@wson 5 1,784 03-06-2012, 11:22 AM
Last Post: D@wson
