06-02-2014, 08:41 AM
Right, to kick things off I've had a couple of occasions where the speedo will dart round to 110mph with the trip counter fully lit-up (as in all 000's) then back off again. Normally I'd say battery past its' best? Although I seem to remember it being all of the gauges before. No battery warning light or any other symptoms.
Next issue is dashboard illumination; ocassionally whilst driving along they will go out...then come back on again. Fiddling with the dimmer switch brings them back on. I reckon it could be the dimmer switch itself? Or at least the wiring to it?
Finally, one which has been p*ssing me off a while now, the coolant level warning light. The coolant level is fine, so the sensor is playing up. Should I get a new one or is it easy to remove and clean up? Do you lose coolant when servicing the sensor?
And now my aux belt is squealing like a pig. I only replaced it 9 months ago!!
