	Threads: 141
 35
		Collected my subframe earlier and set about refitting everything. Finally got everything ready to get the car on the road! (some assembly required)
 81
		Seen this on Facebook. Looks lovely.
	Threads: 141
 35
		Got a lot done today, inspired to get it on the road quicker than ever now I know how cheap it is to insure this year
Anyway, subframe fitted, interesting job by yourself involving balancing it on my shoulder while putting the bolts through with my free hand lol
Really glad I got it coated as it instantly makes everything underneath look 10x better
While the exhaust and gear linkages are off i finally got around to fitting the quickshift I've had for around 2 years
Took about an hour of fiddling with the length of the shaft (giggedy)  to get it right, be interested to see how it is whilst driving, but just from changing gear sat in the car it feels a million times better than the knackered nylon ball did
I'll carry on tomorrow, hoping to get the struts and remaining front end back together and as much else as there's time for
 81
		what quickshift is that? is it the original stuck or have you transferred the reverse mechanism?
	Threads: 141
 35
		 (25-06-2016, 09:18 PM)Eeyore Wrote:  what quickshift is that? is it the original stuck or have you transferred the reverse mechanism?
Baker bm one I bought ages ago and forgot I had until I came across it earlier
I just carefully cut the reverse collar off then glued it back together once I'd set the throw how I wanted
	Threads: 141
 35
		Suspension and brakes done :
Hubs cleaned and coated with zinc paint, ran a thread cutting die down the wheel studs to clean the threads out and refitted with fresh loctite.
New strut top mounts and bearings, Bilsteins and eibachs fitted with new pinch bolts.
Brembos serviced, cleaned and built back up with plenty of copper grease in an attempt to keep the squeal at bay.
New droplinks and track rod ends while I was there, all ready to go on the running gear side of things now
	Threads: 541
 124
	Threads: 141
 35
		Electric power steering pump mounted and connected, fits quite nicely in the same location as it would be on the 106 it was liberated from originally
Also a massive thanks to Matt for lending me his scorpion exhaust until I can sort my own exhaust out. What a sir
	Threads: 102
 18
		Remind me what you said about scorpion exhausts on fb?
Looking very nice though!
	Threads: 141
 35
		 (01-07-2016, 08:36 PM)RetroPug Wrote:  Remind me what you said about scorpion exhausts on fb?
Isn't my first choice of system sure, but I'm willing to give it a good try :
It's a million times better than my blowing magnex already haha
	Threads: 120
 35
		Welcome sir    at least one of our 306's will be at pugfest
Team Cyril
	Threads: 102
 18
	Threads: 141
 35
		Productive afternoon today, cars 90% done, hopefully finish it in the morning :
Brakes bled with fresh 5.1 fluid, arch liners back on the front, scorpion exhaust fitted (much better fit than the magnex) with new exhaust gaskets, clamps and fitting kit, silicone coolant hoses fitted, proper gti6 Nissens radiator, welded on some new brackets for the oil cooler, cleaned out all the leaves under the scuttle, tidied up some wiring, new numberplates, fuel lines refitted along with new stainless clips throughout the engine bay.
Tomorrow I've got to wire the cooling fans in, service items, slam panel, lights and front bumper back on plus whatever I forgot today
		Good effort pal...
Actually rather excited about seeing this.
	Threads: 541
 124
		Again, like Piggy I'm rather excited to see this in the flesh but shouldn't the discs be the other way round?
		Looks so nice!!  Be a shame to take it outside and ruin it now.
	Threads: 141
 35
		03-07-2016, 07:43 PM
(This post was last modified: 03-07-2016, 07:54 PM by ozonehostile.)
		 (03-07-2016, 10:26 AM)Dum-Dum Wrote:  Again, like Piggy I'm rather excited to see this in the flesh but shouldn't the discs be the other way round?
Aha you're not the first person to bring it up, I've talked to loads of people about it and basically come to the conclusion that the fins should be cutting into the pad and then centrifugal force flings hot dust out. I've had them both ways around and noticed no difference so I'll just stick with what motorsporty type people have told me
 (03-07-2016, 10:54 AM)Toms306 Wrote:  Looks so nice!!  Be a shame to take it outside and ruin it now.
Aha it will be kind of heartbreaking to take it out of the unit and across the gravely mud outside
Another good day spent on the car, although annoyingly it isn't quite ready to get on its wheels and road test yet, mostly due to having to work around problems that I've created by moving things around under the bonnet.
With the new epas setup there was no longer any room for the original air intake setup I made so after about an hour of trying to move it around in a load of different places I've just had to put the biggest filter I could fit straight on the throttle body then make as good an air flow I could with the space given.
Next problem, getting reverse to engage with the new quickshift. Lots of fiddling around with collars and shaft length (inb4giggedy) again.
All front end went back together with no problems, become quite quick with the old 306 face on/off routine haha
Oil changed, new spark plugs, new gear oil including redline lsd additive, thankfully there are no leaked from the diff housing, cooling fans wired in, epas pump wired in, coolant bled, interior reassembled, handbrake cables tensioned, and replaced all the tarnished engine bay bolts I could find with nice new ones
I'll be straight over after work tomorrow to get the last few jobs done
	Threads: 371
 29
 Car Model/Spec: ford fiesta
		getting close now then man. looks epic.
	Threads: 141
 35
		 (03-07-2016, 07:58 PM)bashbarnard Wrote:  getting close now then man. looks epic.
Cheers buddy, can't wait to drive it now!
	Threads: 47
 14
 Car Model/Spec: Ford cougar v6.  Mk6 Transit
	Given 20 thank(s) in 20 post(s)
		Awesome work every time I open this thread.
One of the cleanest 306s out there.
        I Don't Have A 306.
	Threads: 141
 35
		 (03-07-2016, 08:19 PM)Danny Wideboy Wrote:  Awesome work every time I open this thread.
Thanks buddy
	Threads: 102
 18
		What everyone else said, really nice work and very, very clean car. Lots of things on here that I aspire to do to mine someday.
	Threads: 58
		Hope your ready for the manliest gearbox knock ever
"knock knock" said the man diff!
"Dude your cvs are hanging" No there not shut up ha!
	Threads: 141
 35
		03-07-2016, 09:40 PM
(This post was last modified: 03-07-2016, 09:43 PM by ozonehostile.)
		 (03-07-2016, 09:31 PM)Stef205 Wrote:  Hope your ready for the manliest gearbox knock ever
Haha I have heard about how noisey the 3j can be    looking on the 6 forum about them, the redline friction modifier seems to help
 (03-07-2016, 09:12 PM)RetroPug Wrote:  What everyone else said, really nice work and very, very clean car. Lots of things on here that I aspire to do to mine someday.
Thanks man, it's nice that it's taking shape after 6 months being stuck on the ramp
	Threads: 58
		yeah ive abit in mine not too much as it will stop the plates from doing there thing
	Threads: 120
 35
		Cracking stuff dude! if you need help in the evenings you know my time is free for you too use
Team Cyril
	Threads: 141
 35
		Well, it runs!
Couple of problems with the power steering, firstly a huge leak from the return pipe from a split I failed to notice, and the switching doesn't seem to work properly, as it doesn't always turn the pump off when the ignition goes off, but very nearly there!
Straightened the tracking the best I could without the proper equipment, it ought to be good enough to drive to the tyre place to have laser alignment.
Even put the compomotives on, a sight I haven't seen for a long time
	Threads: 47
 14
		Dem rimz....
        I Don't Have A 306.
	Threads: 120
 35
		I have found the magnex centre pipe.. just saying    left it behind the old 205 door for you behind my unit dude
Team Cyril
	Threads: 141
 35
		 (05-07-2016, 07:07 AM)Matt-Rallye Wrote:  I have found the magnex centre pipe.. just saying   left it behind the old 205 door for you behind my unit dude
Ah legend sir!
I shall retrieve that later then see what can be made of it after pugfest
