I've never failed to remove a hub nut with it. And only once failed to remove a HDi crank pulley nut...but I couldn't remove that one with a bar either, no idea how it'd seized so badly!
It's mains though, not battery! I specifically didn't want a battery one as my battery drill is useless lol.
Car Model/Spec: 306 D Turbo
Sig update required I think.
Team 35mm socket! Lol
Who has the 27mm injector socket then?
I do I do!!!
306 specialist tools ftw
27mm socket? With the right engine you only need a 13mm...
Threads: 87
48
(10-11-2014, 06:38 PM)londondan86 Wrote: Sig update required I think.
I do I do!!!
Here sir here, I do sir
The right engine is never going to be a ford I'm afraid Tom!!!
Out come the xud owners eh Matt?!
10-11-2014, 06:46 PM
(This post was last modified: 10-11-2014, 06:46 PM by Toms306.)
Unfortunately my Ford has a crappy Peugeot engine in it.
But regardless, I meant the HDi only needs 13mm lol...this is a 306 forum you know...
Threads: 87
48
10-11-2014, 06:54 PM
(This post was last modified: 10-11-2014, 06:55 PM by Toms306.)
Its an internet forum...you're allowed opinions on things you've never owned/seen/heard of...
You're right though, I haven't owned one, have test driven a couple (hence never buying one!  ) and worked on one or two. I do intend to own one at some point though. I've never owned a '6 either!
Touché!!! But I wouldn't quite call a 13mm a specialist tool now! A 13.43mm that's required to remove the racoon filter on a 6. That's specialist!
I know Matt but for Tom it's not "refined" enough :yawn:
Threads: 87
48
Joking aside I don't know how anyone wouldn't enjoy a big blown xud or even a good stage 1 like my old one, great fun and you get to keep your clothes on
10-11-2014, 06:59 PM
(This post was last modified: 10-11-2014, 07:06 PM by Toms306.)
That was my point...don't need to waste money on special tools with the right engine.  Well expect the electronic magical cam belt tension tool....but just give it a twist and hope for the best lol.
(10-11-2014, 06:58 PM)Mattcheese31 Wrote: Joking aside I don't know how anyone wouldn't enjoy a big blown xud or even a good stage 1 like my old one, great fun and you get to keep your clothes on
People have different preferences though... Like I can't think of an enjoyable activity without clothes on, but I'm sure you can.
In all honesty, I wouldn't enjoy a big blown XUD, I'd constantly be worrying about rod's falling out or turbos exploding and the engine running away. I'm fully aware this won't be understood by none-worriers who can just 'enjoy' things lol.
I gota 27mm injector socket
Anyone else got a custom 13mm home brew spanner for the three bosch pump bracket bolts??
(10-11-2014, 07:08 PM)Piggy Wrote: I gota 27mm injector socket
I have indeed! And a paint roller lock off tool!!!
Threads: 87
48
Haha, this is the real shit right here, probs ought to do a little guide on special win tools needed for xud
Good idea Matt. Let's also not forget the telescopic magnet for picking up lost bolts from behind the pump/alternator/oil filler neck!!
Threads: 87
48
(10-11-2014, 07:31 PM)londondan86 Wrote: Good idea Matt. Let's also not forget the telescopic magnet for picking up lost bolts from behind the pump/alternator/oil filler neck!!
Haha check..
Telescopic magnet is a must for any car!!
Spent half an hour looking for mine earlier...before remembering I now have a glovebox big enough to put things in and that's where it was.
Threads: 87
48
I have a glove box big enough to put things in, it's not called phase win for nowt Tha noz
10-11-2014, 08:25 PM
(This post was last modified: 10-11-2014, 08:26 PM by Piggy.)
Yup, I got a smoothed and shaped old bolt for the locking pin, and the relevant bolts for cam and pump!
I will be making a custom 13mm spanner and socket for the fuel adjustment nut and screw too soon!
(telescopic magnet with an LED on the end for the win!  )
Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
(10-11-2014, 07:34 PM)Toms306 Wrote: Telescopic magnet is a must for any car!!
I was poking around behind the dashboard with my magnet after a nut that fell in, the magnet stuck to something and i pulled it put, only to realize the magnet had come loose from the stick and still remains in the depths of the dash
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
Haha, you need a stronger magnet to get that one back now...
Threads: 541
124
I has a 27mm socket and spanner (TBH i prefer the spanner on injectors for some reason)
I also have the 13mm "half moon" or "obstruction" spanner as they are sometimes called that was designed for stuff like bosch pump bolts.
I have 2 or 3 different ones of these with different strength/size magnets for different bolts/clips in different places.
