Loud turbo whistle
Loud turbo whistle
Hi my turbo seems to have started a loud whistle can anyone identify why it's started this
Has the cat pipe split? Boost pipe split/fallen off?
(12-03-2014, 11:06 PM)Toms306 Wrote: Has the cat pipe split? Boost pipe split/fallen off?
It's been de catted and could be it dosnt seem to have lost any power
Did it start when you decatted it? If so that's fairly normal, removing the cat means the sound resonates up and down the exhaust more.
(13-03-2014, 06:35 AM)Poodle Wrote: Did it start when you decatted it? If so that's fairly normal, removing the cat means the sound resonates up and down the exhaust more.
The car was decatted when I got it it just sound like the turbo had got louder and when I let off th revs it's like a dump valve sound
Ah ok, that sounds more like a boost leak. Does it have a front mount intercooler fitted or is it standrd?
(13-03-2014, 02:16 PM)Poodle Wrote: Ah ok, that sounds more like a boost leak. Does it have a front mount intercooler fitted or is it standrd?
Standard one at the min
In which case it'll probably be a leak around the short silicone between the turbo and the main plastic boost pipe, can see it through the drivers arch if you take the liner out.
(13-03-2014, 10:07 PM)Poodle Wrote: In which case it'll probably be a leak around the short silicone between the turbo and the main plastic boost pipe, can see it through the drivers arch if you take the liner out.
Thanks will get into it this weekend and let you know what I find lol
Had one a couple of weeks ago with exactly what poodle said, between the turbo outlet and the bottom pipe.
HDI Tuning Ltd
www.hdi-tuning.co.uk
(14-03-2014, 05:26 PM)pro_steve Wrote: Had one a couple of weeks ago with exactly what poodle said, between the turbo outlet and the bottom pipe.
Thanks getting it sorted this weekend
  Loud Tapping On Start td163 15 8,594 07-12-2015, 07:14 AM
Last Post: THE_Liam
  Whistle sounding like blow off valve MY95 9 4,058 13-05-2015, 07:49 AM
Last Post: MY95
  Turbo now really loud LewisG 2 2,478 05-10-2014, 04:28 PM
Last Post: LewisG
