	Threads: 31
Car Model/Spec: 306 1.8
		04-03-2014, 09:35 PM
		Front left wheel bearings going on my ph1... Is it going to be possible to swap the hub from my old ph3 1.8 onto the ph1 as a temporary fix... Or is it going to be easier to just get the bearing done? I don't have a press..
Cheers
	Threads: 45
Car Model/Spec: HDi DTurbo 2001(Y) Astor
		I just swapped my hub for one off eBay saves doing wheel bearing. They're all swappable and fit on to each other as they're all the same but watch out if they're different balljoint sizes.
Team disASTOR?
	Threads: 92
43
		Ph3 is more likely to be 18mm ball joint and ph1 16mm, but they could be the same... measuring is the only way to know
	Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
	Given 5 thank(s) in 5 post(s)
		Take the ball joint with it if needs be
		If its an OEM wishbone the ball joints are bolted on....but will be rusty as hell lol and the torx will just round off when you counterhold it.
Aftermarket arms sometimes have them riveted on which is obviously more difficult to remove.
	Threads: 141
35
		I'd say your easiest option here would be to swap both front hubs for your ph3 ones as you don't want a car with odd balljoint sizes on different sides.
Unless you know someone with a press who would just replace the bearing in the original hub? Might not be that expensive if you remove the hub and get the correct bearing and take the lot to a garage
