Threads: 7
2
Car Model/Spec: 106 slo-nad
Given 7 thank(s) in 7 post(s)
11-12-2013, 10:23 PM
(This post was last modified: 29-07-2020, 02:09 PM by Martin306.)
Welcome to the thread of Turbo NAD, currently still a Slo-NAD with stuck inlet valves
Some of you may recognise this bit of kit:
Bought from Sam last month, and picked up from Jonny in Kendal, because a 400 miles round trip was cheaper than postage! haha.
Here is the 106 that I shall be fitting it to:
Here's the engine I won't be fitting it to:
Reason being, one month after I took this photo, the TUD5B decided to show me how a conrod breaks. So I've got a TUD5 from an M reg in it, only 160,000 on the current engine block. 130,000 on the shell.
That is all
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Image fail.
SOUNDS like it should be an epic little project, depending on what the top 3 pictures show.
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
What plans you got for the clutch?
Threads: 129
11
How did you chuck a rod in a NAD???
Stage 2 XUD Sedan
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Welcome nice to see you on here mate
Interested to see what is in the top pics
Threads: 7
2
(11-12-2013, 10:36 PM)WiNgNuTz Wrote: Image fail.
They all show for me, and show on my other PC too
(11-12-2013, 10:41 PM)Chris_90 Wrote: What plans you got for the clutch?
Not sure, might what a 106 GTi clutch on it, but I expect it to slip as well. It's the torque that kills them. I can see me ending up with a paddle on it.
(11-12-2013, 10:48 PM)strictly_perv Wrote: How did you chuck a rod in a NAD???
Just too much power
I seized the engine 15,000 miles previously. it had been so long I thought I'd gotten away with not changing the big end bearings. Guess I was wrong.
Bent the crank and everything when it finally gave up, ruined the oil pump. rod was so bent I had to use a 4lb hammer to get the piston out of the bore.
Threads: 591
54
106gti clutch will do fine
Threads: 129
11
Haha awesome. I've just bought myself one of these, yes slowest car I've ever driven but the engine has got potential as it's very rev happy. I remember Samass taking me out in his Go-NAD and it was very quick.
Stage 2 XUD Sedan
Threads: 7
2
(11-12-2013, 11:33 PM)Piggy Wrote: 106gti clutch will do fine
I'm not so sure, we'll see what happens. I'm going to boost it until I bend a rod.
(12-12-2013, 07:18 AM)strictly_perv Wrote: Haha awesome. I've just bought myself one of these, yes slowest car I've ever driven but the engine has got potential as it's very rev happy. I remember Samass taking me out in his Go-NAD and it was very quick.
Yeah, peak power at 5000rpm, and the governer under load stops you dead on 4800-5000 so you can't even get peak hp!
I only ever saw videos of it driving fast Sam had no rev counter though, I've got one of those
The inlet mani was leaking helluva boost though, could have done much more with it.
Threads: 36
2
Car Model/Spec: PH2 Dturbo
Wonder what 30psi would be like in a nad... DO IT!
Threads: 581
195
Given 81 thank(s) in 77 post(s)
(12-12-2013, 09:15 PM)Dean Wrote: Wonder what 30psi would be like in a nad... DO IT!
Its epic! Sams old TNAD kept up with my 6 until about 50 lol
Threads: 42
2
Car Model/Spec: 1.9 XUD
(12-12-2013, 09:17 PM)Niall Wrote: (12-12-2013, 09:15 PM)Dean Wrote: Wonder what 30psi would be like in a nad... DO IT!
That was probably down to your driving skills though
Threads: 581
195
(12-12-2013, 09:23 PM)c.gerrard Wrote: (12-12-2013, 09:17 PM)Niall Wrote: (12-12-2013, 09:15 PM)Dean Wrote: Wonder what 30psi would be like in a nad... DO IT!
Probably but regardless, it was still bloody quick for a 1.5 lol
Threads: 7
2
Anyone know what the break pressure is for the injectors coupled to a Bosch VE pump is?
Threads: 343
15
Threads: 7
2
(12-12-2013, 10:24 PM)Martin306 Wrote: Anyone know what the break pressure is for the injectors coupled to a Bosch VE pump is?
anyone? ^^^
Also, I've got a choice for head gaskets too for the TUD 5.
Now, There's a fibre head gasket or a multilayer steel one available. Which one do I go for? both appear to the the same thickness, but my thinking is the MLS gasket will be better for me boosting?
Threads: 151
14
Car Model/Spec: 306 D-turbo
Mel's gasket even on a standard engine fibre ones are shite
Team Doesn't own a 306
Threads: 7
2
(15-12-2013, 03:01 PM)Danny2009 Wrote: Mel's gasket even on a standard engine fibre ones are shite
Thanks
I've just had like, 6 replies telling me fibre is a waste of time
MLS gasket it is!
Threads: 7
2
Can someone tell me what's so bad about the Lucas pump?
There also appears to be a threaded plug which can be removed for added boost compensator? at least the hole is in the right place anyway.
Threads: 343
15
Were is this threaded plug? you sure your not looking at the black plastic cover that covers the max fuel screw?
Bosch 106 injectors brake at 120bar i believe, Im using 106 lucus injectors on the 306 bosch ve pump, i believe samass was still using the lucus injectors so wouldn't worry about injectors.
Threads: 7
2
(16-12-2013, 09:53 AM)Chris_90 Wrote: Were is this threaded plug? you sure your not looking at the black plastic cover that covers the max fuel screw?
I was just seeing things. No, not the black plug I've already been in there
There was a threaded blank along to the right and "up" a bit. But it's not that.
Yeah I know the spec of the 106 injectors 120-125BAR. was just wondering about the VE pump, if it was suitable. I know it worked on sams one though so I'm not too worried
Lucas are 130-135BAR.
Threads: 343
15
306 bosch injectors brake at 175 bar i believe, like i say tho dont worry about them, if you are worried just get them to a diesel company and make them brake at a higher pressure
Threads: 7
2
(16-12-2013, 12:08 PM)Chris_90 Wrote: 306 bosch injectors brake at 175 bar i believe, like i say tho dont worry about them, if you are worried just get them to a diesel company and make them brake at a higher pressure
I know how to change the break pressure
My only difficulty would be splitting the injector to change the shim. 0.1mm shim adds about 15 BAR to the break pressure.
So I need to add 0.3mm to make them 175 BAR.
Or I could just get somewhere to do it for me probably easier that way.
Threads: 7
2
Everyone should now be able to see the top 3 pics I had them linked from 106oc before, but hosting them elsewhere now
Threads: 7
2
Yawwwwwwn I've been lazy, and also it's dark when I get home from work but lighter evenings are coming!!!
Anyone got a Bosch pump they want rid of?
Threads: 163
53
Car Model/Spec: 406 HDI
How did I miss this? Any progress?
Threads: 7
2
(24-01-2014, 06:07 PM)THE_Liam Wrote: How did I miss this? Any progress?
I've been asking for ages, about just whacking the turbo on with the NAD pump and seeing what boost it makes and not touching fuelling yet. Everyone keeps putting me off, oh you'll get high combustion temps blah blah.
afaik, diesel engine would simply slow down if I added too much air.
I'm stuck, because it's my only car and I can't get the armour off the pump. So I really need to source a DT pump I think, I can't have my car off the road.
Threads: 163
53
Scrapyards still turn up Bosch pumps now and again, go scouting!
Threads: 7
2
(24-01-2014, 06:12 PM)THE_Liam Wrote: Scrapyards still turn up Bosch pumps now and again, go scouting!
guy at my local yard can be a bit of a prick.
I did see a Bosch pump on an old disco, how similar do you think it was? looked identical to the 306/405 one.
Might go for a scan again tomorrow, I'm sure I could make up a story about how much I don't need it. lol
Threads: 163
53
No good mate, it'd have a 6 pot camplate on it if its a 200/300 TDI...
