Threads: 142
58
Car Model/Spec: E46 BMW 320d
As some of you know, i'm currently having a lot of problems with my car, namely i havent got any money to fix the problems that keep cropping up....but i had a new one surface today.
Basically, popped to the shop to get some bits, and when i got back in the car, put the key in the ignition, turned to the second click to heat the glowplugs, and when the light went out i turned the key as usual to start it......except nothing happened. Everything went dead. No instruments, no lights....nothing. Turned the key back to off, then tried again....same thing. Tried again, this time the dash clicks off as i turn the key to the second notch, almost like something is tripping out.  Tried a few more times, and just when im beginning to give up hope of getting it started, lo and behold all the lights work, the glow plugs heat, and when i turn the key, the old girl splutters in to life!
I kinda dismissed it the first time it happened, but it did it to me on 2 more occasions today, making me late to pick the kids up from school in the last instance! Anyone got any suggestions, or should i just throw a match at the damn thing?
Well that's odd!
It sounds like a dying battery but if that was the case it wouldn't start after a few attempts.
Just a stab in the dark really but I'd check the battery terminals are tight and the gearbox earth is still good. Might only take a 'shuffle' in the car to break the connection if anything is loose, especially if the battery isn't great. If all that's fine, I guess it maybe a faulty ignition switch, don't really hear of them failing though!
Threads: 142
58
I thought battery as well until it fired into life as if nothing was wrong!
I did check the battery terminals (both fine), but didnt think to check the gearbox earth tbf, might do that tomorrow.
Threads: 92
43
Its the starter motor sticking, give it a little tap and itll fire straight up. But youll want to get it sorted as soon as, cause it will eventually die. I went about a month or 2 like that till it died. Good news is that all xud, dw starters are compatible, ive currently got an XUD11 starter on my HDi
Threads: 177
Sounds like a loose connection at the battery to me
Threads: 142
58
(06-12-2013, 11:29 PM)Connor Wrote: Its the starter motor sticking, give it a little tap and itll fire straight up. But youll want to get it sorted as soon as, cause it will eventually die. I went about a month or 2 like that till it died. Good news is that all xud, dw starters are compatible, ive currently got an XUD11 starter on my HDi
Cool.....anyone got a spare starter motor they want to give me out of sympathy?
(06-12-2013, 11:41 PM)Daniel306 Wrote: Sounds like a loose connection at the battery to me
Checked the battery terminals, they're both fine.
Threads: 448
51
Dude I'm going to the scrappy tomorrow if they have one ill get it for you. Have it for price of postage
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Hit the battery clamp and terminal with a hammer...worked for me lol
Threads: 142
58
Anyone on my facebook will may have seen the post i put up last night, thankfully i didnt get very far before a mate let us know that i only had the right tail light working. No number plate lights and no left hand tail light. At this point, i left my car at mums and borrowed her Micra to get the kids home.  That turned out to be a fuse, but still leaves the issue with starting.
Changed the fuse, tried to start the car and nothing, tried a couple of times before realising that the interior lights were REALLY dim (as if dead battery). Took a spare battery out to swap and try, as well as a voltmeter. When we checked the battery on the car, it was fine. Reconnected it, and all the lights were fine, and the car started first time, no problem.
I am at a loss to explain this, i can't see how the starter motor sticking would cause such issues? Feel free to correct me, but are there any other thoughts?
Threads: 92
43
Its definitely the starter mate, I had EXACTLY the same issues. Sometimes it would go first time, other its would take a few on and off flicks. When you turn the key to try and start it, all the electricity goes to the starter motor, which is why all the dash lights go out and when you release the key they all come back, this is what always happens, its just that the starter isnt starting the engine. Hopefully that helps explain it for you as that's about as simplified as I can describe it whilst typing on my phone lol
sounds like terminals were dodgy or the starter...
I drove around with a hammer for ages to tap the starter on me Colt Gti...till i got bored of doing it in the rain and refurbed it!
Threads: 178
28
Car Model/Spec: HDi!
i had to carry an end of a strut brace round in the gti to hit the starter with. was annoying!
Threads: 142
58
Fair enough, i'll get on it then, same as i am with everything!
Cheers for the replies guys.
Threads: 92
43
Should have believed me in the first place
Threads: 142
58
Can't argue that really.
Threads: 142
58
Ok, so im thinking it may not be the starter motor thats causing this problem now, as the last couple of days have seen a bit of a development. After originally posting this thread, the problem kinda went away for a few days, but then came back with a vengeance. Thursday evening when i finished work, i got in the car and when i tried to start it, i got nothing. Gave the starter a few love taps with my big tool (giggidy), still nothing. A few more taps later, and the starter turns, but by this point, the battery is so weak, it will not fire. Ended up having to bumpstart it down the nearest hill. Then all was fine again until yesterday. Went to take my brother to work, and i had nothing at all, no dash lights on first OR second click, and really dim interior lights. Borrowed mums car to take him to work, but when i went to get the missus from her work, again, nothing. Got a mate to give me a jump, and it fired up first time, no problem. Got home no worries, then go to take the missus to work again this morning, and its deader than a dead thing...dim interior lights again, and nothing from the dash.
Is Connor gonna come along and tell me its still the starter motor, or could i be right in thinking it could be the battery/alternator? Worst thing is that the battery is the one that i ran in the China 1.4, and is only rated at 400A, so its always been a bit lethargic in starting a diesel. Could i have cooked the battery? And where the hell am i meant to get a replacement on a frigging Sunday!?!
Threads: 136
11
Get a volt meter and check what voltage the alternator is giving out, should be 14.4v when car is running
Also give the battery terminals a clean with sand paper and make sure they are contacting properly
Thirdly check the fly lead to the alternator, smaller wire out of the 2 and make sure that has a decent connection
Threads: 142
58
Cheers man, will check the above. I know the terminals are good, that was one of the first things i checked!
If i can get her started and round to my mums, i can get my bro with his voltmeter and check everything over.
Threads: 136
11
Also if it's not starting try crossing the terminals on the starter see if it jumps to life.
The solenoid wire might be giving up
Threads: 142
58
By "crossing the terminals", i assume you mean connecting the two with a screwdriver or similar?
Threads: 92
43
Its still the starter mate, just seems like youve killed your small battery in the process
Threads: 142
58
Tbh mate, I'm now beginning to wonder if this particular issue is a culmination of numerous different problems. Starter, coupled with a lousy battery, and maybe a dodgy alternator or something related to it. Just getting tired of this shit now.
Threads: 151
14
Car Model/Spec: 306 D-turbo
You tested the alternator? Seen what volts battery is putting out when running
Don't most garages test your battery for free?
Sorry not read the thread
Shame your so far away I have a battery that's as long as the glovebox is wide never have a problem again
Team Doesn't own a 306
Threads: 142
58
Not yet I haven't mate, but that's the next thing I'm gonna check. Cars running at the moment, so that's something at least!
Threads: 151
14
Need it sorting before snow not ideal bumping in it lol
Threads: 142
58
I quite agree mate, but as soon as I've got to my mums, I can get a voltmeter on the alternator, and see what's going on.
Threads: 7
Car Model/Spec: 106 slo-nad
Given 7 thank(s) in 7 post(s)
I had this problem with my TUD.
Combination of old battery, dirty terminals, terminals felt tight but you could turn them with pliers!
I don't think it'll be your starter, saying that I saw the state of one on a 2.0 HDi a while back and it was proper choked with oily crap.
If it were your starter, the dash lights would come on every time, and you'd have a no start when you turned to "start" position when it either shorts the battery or sticks. I see no reason it would cause your lights to dim etc.  no?
Threads: 136
11
Agreed it's not your starter
Threads: 142
58
I'm currently thinking that battery is root cause, but starter could do with replacing as well. Just tested the alternator, and it's giving a steady 14.4v, so alls well there. I have a few people offering me batteries at the moment, so I'll get that replaced and see what happens. Starter is now on the list of things to replace as well.
Threads: 226
24
Car Model/Spec: A3 TDi
Typical that I scrapped a starter a few weeks back!
