26-10-2013, 04:37 PM
Petty in veg
26-10-2013, 04:46 PM
ok cool, thanks
28-10-2013, 10:52 AM
Check for air ingress into the fuel system as well, is a common problem.
28-10-2013, 12:05 PM
that a diesel engine is not designed to run on petrol!!!
(28-10-2013, 12:05 PM)Piggy Wrote: that a diesel engine is not designed to run on petrol!!! Is it not? Dam that's were I've been going wong all this time ![]() What problems is it gonna cause? What's the max % to use? 10% 20%
28-10-2013, 12:17 PM
Personally don't go over 10%, normally 5% is sufficient.
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
28-10-2013, 12:36 PM
(28-10-2013, 12:17 PM)Anton Wrote: Personally don't go over 10%, normally 5% is sufficient. Thanks I'm running it at 10% now so won't go over that, it's only the first start I have issue with looking at haveing a small tank for derv and twin tank it so start on derv and switch to Veg oil, but struggling to find an electronic 3 way valve to switch Fuel, any one no we're I can get one from?
28-10-2013, 12:39 PM
(28-10-2013, 12:36 PM)Chris_90 Wrote:(28-10-2013, 12:17 PM)Anton Wrote: Personally don't go over 10%, normally 5% is sufficient. you don't need to do that mate, your problem lies elsewhere . .
28-10-2013, 12:49 PM
yeah thats waaaaaaay too much hassle for really no gains.
just get the mix right/decent oil. Mine started bang on every morning last year all through that snow, and that was 90% veg and 10% diesel as I had a load of diesel given me in jerrys. But I had sorted all the little air ingress places and sorted decent plugs n battery. 2/3turns of the engine and away with a little chuckle to itself for 10/15seconds then fine. Wishes for more power...
28-10-2013, 12:58 PM
I will have to see how it goes when it's colder. Last winter in d turbo I put 13 liters of derv in a full tank of veg and it was ok, but I was having issues a few weeks ago so had to start mixing petrol and it's been ok since. See what it's like when it's colder
29-10-2013, 09:04 PM
(28-10-2013, 12:10 PM)Chris_90 Wrote:(28-10-2013, 12:05 PM)Piggy Wrote: that a diesel engine is not designed to run on petrol!!! Delubrciates the pump bud. Can cause seizures as well.
29-10-2013, 09:52 PM
(29-10-2013, 09:04 PM)306Puggy Wrote:(28-10-2013, 12:10 PM)Chris_90 Wrote:(28-10-2013, 12:05 PM)Piggy Wrote: that a diesel engine is not designed to run on petrol!!! Should have said I'm adding 200ml of 2 stroke to every tank to
31-10-2013, 12:51 PM
Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning
31-10-2013, 12:55 PM
(31-10-2013, 12:51 PM)THE_Liam Wrote: Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning I've started parking car on road so if it be's a nob I can bump it lol the joys of veg oil
31-10-2013, 02:56 PM
(31-10-2013, 12:55 PM)Chris_90 Wrote:(31-10-2013, 12:51 PM)THE_Liam Wrote: Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning Having tried to bump a car on veg oil, good luck with that
31-10-2013, 03:21 PM
(31-10-2013, 02:56 PM)THE_Liam Wrote:(31-10-2013, 12:55 PM)Chris_90 Wrote:(31-10-2013, 12:51 PM)THE_Liam Wrote: Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning When I had issues before that's what I did bumped first time
