Threads: 40
Car Model/Spec: 2.0Ltr HDI
Soooooo as of Friday, my light saying I have no traction has been coming on and staying on, anybody have any thoughts as to why?
pic:
I am clearly parked up so how I have lost traction?? :S
thanks in advance
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Threads: 541
124
Thats the ABS light, check the fuse and if not get the codes read to tell you which sensor it is.
Its defo not a MAF sensor issue
Threads: 195
6
Hmmm after putting my glasses back on my face I can see now it is a ABS light loool
Threads: 40
20-10-2013, 08:41 PM
(This post was last modified: 20-10-2013, 08:42 PM by DazzaHDI.)
ok sound, will have a look tomorrow. My abs still works though?? I tried it yesterday.
+ had a blonde moment and forgot it was called ABS!!
I wish 306s had traction control.
If the light is on, the ABS won't work, it defaults to 'off' as a safety precaution.
Threads: 202
58
(20-10-2013, 08:47 PM)Toms306 Wrote: I wish 306s had traction control.
They do, it's called "the driver"
(20-10-2013, 08:54 PM)Jonny81191 Wrote: (20-10-2013, 08:47 PM)Toms306 Wrote: I wish 306s had traction control.
Lol was just about to say, if you NEED traction control, you really need to learn how to drive.
20-10-2013, 09:00 PM
(This post was last modified: 20-10-2013, 09:01 PM by Toms306.)
Don't 'need' it, I'm just a lazy shit and don't like wasting tyre tread when pulling out sharp in the wet.
One of the most annoying things about the Vectra or a HDi is that it requires effort to avoid slipping tyres in those circumstances, I've no idea who thought a torquey diesel could do without TC, its so easy to add when the ABS system is already there and saves so many tyres through the life of the vehicle!
Threads: 202
58
(20-10-2013, 09:00 PM)Toms306 Wrote: Don't 'need' it, I'm just a lazy shit and don't like wasting tyre tread when pulling out sharp in the wet.
One of the most annoying things about the Vectra is that it requires effort to avoid slipping tyres in those circumstances, I've no idea who thought a torquey diesel could do without TC, its so easy to add when the ABS system is already there and saves so many tyres!
Alternatively, don't use the clutch as a switch?
One of the most annoying things about the Vectra or a HDi is that it requires effort to avoid slipping tyres in those circumstances, I've no idea who thought a torquey diesel could do without TC, its so easy to add when the ABS system is already there and saves so many tyres!
Tom you do need to learn how to use a clutch then! You cant say just because its a diesel, you need TC to pull away.
Threads: 202
58
I think this must be how tom drives!
20-10-2013, 09:09 PM
(This post was last modified: 20-10-2013, 09:20 PM by Toms306.)
Yawn, I already said you don't 'need' it!
It's not my clutch control either....you should see the amount of tyre receipts are in the Vectra's SH compared to the Golfs lol.
And Jonny - hell no, after having the Golf with a slippy clutch I soon learned to pull away almost at idle and then boot it.... In the Vectra you just end up doing a hotrod start with both tyres spinning though.  It has a lot to do with inertia though, don't forget the Vectra weighs about 5 tonnes so sticking torque through the tyres just causes them to lose grip instantly. Oh, and I'm on rainsports before anyone says its the tyres. I will admit they don't go sideways in the wet, but they struggle with power forwards lol....
And frankly I'm a lazy bugger, I just like to point and boot.....  Would much rather a computer sorted it out rather than having to put the effort in myself.... I know you people that 'enjoy the drive' won't understand that at all though.
Threads: 202
58
20-10-2013, 09:24 PM
(This post was last modified: 20-10-2013, 09:26 PM by Toms306.)
Threads: 40
Ladies ladies, calm down
Back on topic, my ABS definitely doesn't work when this light is on, tried it out tonight, forgot my seat was broken!! Lol anywayssss, it's not on constantly, like earlier, 30 minute journey, it came on 5 mins before I was home but when it's on it stays on, what could be causing this? As don't you nee the fault to be showing for it to come up on a diagnostic?
Could somebody also tell me where the fuse is located please as I never got an owners handbook or manual or anything g like that when I bought the car.
Thanks again
I already told you it wont work with the light on.  And everyone is calm... Or atleast I am, maybe Nialls raging at the fact I like an electronic driver aid, I dunno.
On topic though, it's probably a dirty ABS sensor/ring, I'd check those first. If they look clean try a voltage test - basically connect the sensor to a multimeter and you should see a voltage as you spin the wheel. Also I believe you can see the ABS logged faults without the light on but not totally sure on that.
Threads: 252
7
Cruise control.would be far better tbh
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 9
Car Model/Spec: 2001 hdi estate
mine was the same, the abs ring on the nsf had snapped. 99p replacement of ebay, i just beed to fit it now get it fitted now.
if it is down to a damaged abs ring make sure you find the correct one as their are 2 types fitted.
one with teeth and one with small rectangular holes
https://www.google.co.uk/search?q=306+ab...80&bih=899
