banging from fuel tank?
hi dont know if this is the right place to post but just recently a noise has appered and im not to sure what its is! its hard to explain but its like an empty tank retracting in size and its comming from the fuel tank now this worries me now ive had alook at the fuel tank and all looks fine its not getting hot or anything like that so then i thought must be the fuel pump in the tank but it still does it when the engine is off now its defintly the fuel take as you can hear and feel it clear as day ive run out of ideas.
anyone have a clue what this might be?
thanks in advance if anyone does
Sounds like it might be the fuel tank breather blocked or slightly blocked when the car is using fuel it might be sucking tank in a bit only an idea bit worth a try
Why is it that the only thing i can think of is racoons? lmao
/unhelpfulpost
(02-07-2013, 07:36 PM)mikey b Wrote: Sounds like it might be the fuel tank breather blocked or slightly blocked when the car is using fuel it might be sucking tank in a bit only an idea bit worth a try
Where is the breather pipe located? I've got a very long pipe brush that might do the trick Smile
(02-07-2013, 07:38 PM)WiNgNuTz Wrote: Why is it that the only thing i can think of is racoons? lmao
/unhelpfulpost
You say raccoon strangly I think of kebabs lol
What's it on a petrol or derv it might be buy the tank or up by the filler pipe not to sure some one on here will prob tell ya straight away
(03-07-2013, 08:49 AM)mikey b Wrote: What's it on a petrol or derv it might be buy the tank or up by the filler pipe not to sure some one on here will prob tell ya straight away
It's a 2.0 petrol mate
Possibly loose heat shield underneath?
(03-07-2013, 03:28 PM)Niall Wrote: Possibly loose heat shield underneath?
its not that kinda noise mate more like a pop
That'll be why this is in the "xu" petrol section then... Tongue
[/quote]
[/quote]
Rofl
Tiger in the Tank?
you using Esso fuel
(03-07-2013, 04:33 PM)cully Wrote: Tiger in the Tank?
you using Esso fuel
I really hope not lol and yes using esso fuel
We'll I drilled a hole in the fuel cap and now it's fine lol
you using Esso fuel
lmao
Missed the gist of that pun? lol
Are you sure the mounting braces under the car are tightened properly? Theres no play in the tank where it is mounted?
he fixed it with a hole in the filler cap...
so the noise is clearly the expansion/retraction of the tank as it empties...
so breather hose must be blocked I would say
I really should read the whole thread properly rather than skim reading lol
Fair enough, glad he got it sorted.
(07-07-2013, 07:09 AM)Piggy Wrote: he fixed it with a hole in the filler cap...
The only breather I could find was behind the the cap it's self! So would of bin coming out and straight back in! Do they normally have a hole in the fuel cap as. Mine didn't
you using Esso fuel
lmao
Are you sure the mountin under the car are tightened properly? Theres no play in the tank where it is mounted?
Yeah I realised after I wrote it lol dint think they used tigers still lol
  Fuel tank elbow - silicone alternative? Dangti6 0 2,119 04-03-2018, 01:31 PM
Last Post: Dangti6
  Severe banging/misfiring RetroPug 12 6,034 16-07-2014, 01:21 PM
Last Post: RetroPug
  Popping and Banging... 9Freedman9 8 4,626 15-02-2014, 02:26 PM
Last Post: S160six
