Fan not kicking in
Fan not kicking in
Hi guys, this wiring doesn't look right to me.. Any advice on what to try to test radiator fan?
And in layman a terms haha, I'm new to pugs Wink
(30-06-2013, 09:28 AM)Northern-john Wrote: Hi guys, this wiring doesn't look right to me.. Any advice on what to try to test radiator fan?
That looks like someone has had summin previously wired in...as for the fans mate most likely thermostat...
(msg sent from hell)
So just a case of re-earthing, and then checking the thermostat?.. Any clues as to where it is?..
(30-06-2013, 12:57 PM)Northern-john Wrote: So just a case of re-earthing, and then checking the thermostat?.. Any clues as to where it is?..
Usualy on the radiator mate
Does yours have AC? If so, i unplug the brown sensor on the thermostat housing with the engine running. If the fans dont kick in on full speed after a few seconds, you need a new Bitron fan controller
(30-06-2013, 03:19 PM)niall Wrote: Does yours have AC? If so, i unplug the brown sensor on the thermostat housing with the engine running. If the fans dont kick in on full speed after a few seconds, you need a new Bitron fan controller
Tried that, and still nothing Sad, but also, checked the thermostat.. And correct me if I'm wrong, but there's part of it missing? Lol
Oh and forgot to add, the ac still works lol
Err yes that is f*cked! lol
In which case mate, you need a new bitron fan controller.
http://www.ebay.co.uk/itm/PEUGEOT-306-40...4ac0e883ef
Thats what you need but its far too expensive!! Ring round some scrappies and you should be able to pick one up for about £20. It lives under the inner wing under the near side headlight. Bit fiddly to replace. Have to take out the arch liner then you can get to it.
