GTi-6 brake upgrade
GTi-6 brake upgrade
It's probably been asked before, but I've just bought some new GTi-6 front caliper and plan to stick them on my D Turbo! Main question is, do I need to change the master cylinder to a GTi-6 one or can I run them on a D Turbo one? Thanks!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
personal prefference really.
I would. others wouldnt.
If you can be arsed to bleed the entire system from head to toe go for it. Might be a nice idea to refresh the brake fluid anyway.
Personally haven't had any issues running without, you'll get used to slightly longer pedal travel, its no biggie really.
(09-06-2013, 01:03 PM)zx_volcane Wrote: If you can be arsed to bleed the entire system from head to toe go for it. Might be a nice idea to refresh the brake fluid anyway.
what he said^^^^^^^^^^^^^^^^^^ . .Smile
Get quite a bit of pedal travel as it is atm, so no worry! Gonna get some mintex disc and pads ordered then get these on!!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Ideal time to fit some braided lines aswell
I'd definitely consider it, I ran standard MC and the pedal travel is shocking, doesn't inspire confidence. Unless you like to feel the brakes working once the pedal is nearly in the carpet...
[Image: Sig500x130.png]
Another quick question, are these brakes the same as the Xsara VTS ones? Can anyone confirm this?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Yeah, check the number stamped near the piston. Should be 57
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
  gti6 brake upgrade problem baz306 9 4,636 20-06-2013, 09:58 AM
Last Post: baz306
  Rear brake upgrade? Ben 17 9,891 10-06-2013, 09:40 PM
Last Post: Anton
  Estate brake upgrade Willo 18 8,142 22-11-2012, 08:04 PM
Last Post: Just Sean
