D Turbo tuning.
D Turbo tuning.
I have a Phase 1 D Turbo S with a Lucas Pump and KKK K14 Turbo. I know this thread has been done a million times, but i'm more concerned about the reliability of the engine. If i was to go for a stage 1 on my car would it be more than safe to run? (Have had bad luck with performance and reliability in the past)
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
It will be fine mate
306 HDI, soon to be XUD
Cheers mate, also, is it mandatory that i use a performance filter/straight through exhaust?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Most seem to say that Peugeot detuned them out the box because of the potential to interfere power wise of the 1.8/XSI
Obviously though if you put more power through things then things can wear out a lot quicker.
There is always a trade off between power and reliability
You don't have to have a performance or free flowing exhaust but it will massively to help get the gasses out and keep EGT's down
(20-05-2013, 11:03 AM)4WayDiablo Wrote: Most seem to say that Peugeot detuned them out the box because of the potential to interfere power wise of the 1.8/XSI
It wouldn't of surprised me to be honest, even by today's standards D Turbo's aren't that bad... Standard engine wear is fine, just don't want my engine to give up because i'm pushing 18-20 PSi through a K14 which I've heard isn't the best turbo either...
The exhaust, as it's a standard de-cat was just thinking of a straight through back box? Also i've heard that because of the pressure difference in the exhaust when straight through can upset the turbo?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Ive been pushing 20psi through a k03. Its made its way down to 17 now...hopefully its on its way out Big Grin
Cant wait to get 24-26 psi on a t2!
K14's take alot of abuse if you keep ontop your oil changes. I read somewhere on here its the biggest of all stock turbos but im not sure :/
(20-05-2013, 12:06 PM)RePT Wrote: Ive been pushing 20psi through a k03. Its made its way down to 17 now...hopefully its on its way out Big Grin
Was looking at a T2 as apparently they're the turbo to have on an XUD (even though a GT15 suits the engine delivery better but the boost comes and goes quick)?
(20-05-2013, 12:27 PM)Tom Wrote: K14's take alot of abuse if you keep ontop your oil changes. I read somewhere on here its the biggest of all stock turbos but im not sure :/
I saw they could only, safely run 20 PSI and that anymore would blow it to bits! Surely a turn of the actuator is 16-18 PSI? Also i know the fuel economy will drop after doing this, but by how much?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
People have run T2's and K14's at 30+ psi, should make over 140bhp with them at that psi. For a stage 1 id be looking at atleast 20psi.
Fuel economy should increase! You've been told quite a bit of rubbish....
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(20-05-2013, 12:45 PM)Anton Wrote: People have run T2's and K14's at 30+ psi, should make over 140bhp with them at that psi. For a stage 1 id be looking at atleast 20psi.
As long as i have confidence in doing 20 PSi then i'll do it.
I have been told a lot of rubbish, but hey, that's why i'm here, try and find out from people who know what they're on about!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Wouldn't bother with more then 24PSI on a TMIC.
If FMIC'd then just keep going.. Tongue
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Slap a bosch and TD04 on it )
[Image: J5hxCcC.jpg]
(20-05-2013, 03:07 PM)silverzx Wrote: Wouldn't bother with more then 24PSI on a TMIC.
Just gonna run it at between 18-20 PSi for a week or two and see how shes runs!
(20-05-2013, 10:25 PM)CJ_Derv Wrote: Slap a bosch and TD04 on it )
That's the dream mate!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Its not really can be done for less than 200 quid if you look in the right places and do the work yourself
Meh... I ran 30psi on my td04 with a top mount... It was fine.
On the 306 waiting list.
until HG went . .didn't it? . . .:p
HG went before I put the turbo on... Then I had the head rebuilt and fitted the td04 while changing the head..
(21-05-2013, 08:19 AM)Jake Wrote: Meh... I ran 30psi on my td04 with a top mount... It was fine.
ahaa fair doos matey . . .Smile
(21-05-2013, 08:32 AM)Mattcheese31 Wrote: until HG went . .didn't it? . . .:p
That's what was good about my DT the engine outlasted everything else !
From what i was hearing, it costed a lot more than £200 to grab a TD04! May not be so long after all!
Why was it not ran on FMIC? That's insane boost
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
(20-05-2013, 11:40 PM)ADV_93 Wrote: Just gonna run it at between 18-20 PSi for a week or two and see how shes runs!
Because I'm a Fking badass that's why...
(I was just too skint to ever but one haha)
I was referring to no point running more than 24 PSI on a standard turbo on a TMIC. Tongue
S14 Zenki Build
(21-05-2013, 07:05 AM)CJ_Derv Wrote: Its not really can be done for less than 200 quid if you look in the right places and do the work yourself
I want this, but on a FMIC
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Check my latest thread TD04 consequences but had a good 12month innings
Right, adjusted the max fuelling by quarter of a turn, and the compensator 1 and a half turns (at 2 and a half turns it wound out) then tried to adjust the wastegate by 1 turn (however the 2.5mm allen key was slightly rounded, so may have to have a go tomorrow with lots of WD40 and some good grips!) Also, connected up a boost gauge and it read 10-12 PSI (but they come standard with 14 PSI, so slightly lost on this?). BUT driving it felt a LOT more torquier and willing to rev! Also, no turbo lag in 2nd gear now!!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
(22-05-2013, 12:28 AM)ADV_93 Wrote: Right, adjusted the max fuelling by quarter of a turn, and the compensator 1 and a half turns (at 2 and a half turns it wound out) then tried to adjust the wastegate by 1 turn (however the 2.5mm allen key was slightly rounded, so may have to have a go tomorrow with lots of WD40 and some good grips!) Also, connected up a boost gauge and it read 10-12 PSI (but they come standard with 14 PSI, so slightly lost on this?). BUT driving it felt a LOT more torquier and willing to rev! Also, no turbo lag in 2nd gear now!!
you wind the wastegate IN mate not out, CLOCKWISE to get more boost pressure . .Smile
Big Grin
I did mate Big Grin! I have read how some people have had to turn it 3 or 4 times to get it doing anything! But driving it, feels like it's boosting a lot more than 10 i tell ya! Gonna have a crack later with a boost gauge try and get it higher! Cambelt and oil change friday hopefully!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
wind it ALL the way in then back it off half a turn mate, that's the way to do it . .Smile
(22-05-2013, 08:14 AM)Mattcheese31 Wrote: you wind the wastegate IN mate not out, CLOCKWISE to get more boost pressure . .Smile
Haha! What boost will that be running then? 26+?! Only aiming for 18!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Just wind the actuator in and control the boost with fueling. Or better fit an MBC, bugger keep adjusting the actuator!
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
  gt2260v turbo tuning wategate depression niciou 8 5,748 09-03-2016, 09:25 AM
Last Post: Dave
  1.9d non turbo tuning karl1989 9 5,106 07-12-2015, 07:26 AM
Last Post: THE_Liam
  Turbo Tuning - Help! philpemberton94 22 10,446 21-05-2014, 01:30 PM
Last Post: philpemberton94
