Threads: 61
2
Car Model/Spec: 306 DT GLX '98
Afternoon all,
Had some fun with 19psi(and still am) but id like to up it to 24.
As title suggests, i have the kkk k14.
What steps must I take to achieve that 23/24 psi of boost?
Running bosch with max fuel.
Threads: 48
5
Car Model/Spec: Peugeot 306 S16 Cossack
Eh? 19psi is a bog standard stage 1. Get an MBC, bet its the wastegate.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 591
54
wind in the turbo some more...
I have a bosch, lda wound pretty far but not ground down, fuel max screw only adjusted a couple turns, k14 turbo wound all way in, then back half turn...
I get 22psi at full chat
Threads: 155
11
Car Model/Spec: Bianca DTurbo
Why on earth have you maxed fuelled the the pump and not sorted the waste gate out? You must be coaling like hell? Sort the waste gate out and turn the fuel down
Threads: 266
18
Car Model/Spec: 205 DTurbo
Took air filter and piping off? Should release a bit more power.
Threads: 150
14
Car Model/Spec: 306 HDI
(19-02-2013, 06:44 PM)silverzx Wrote: Took air filter and piping off? Should release a bit more power.
DoNOT do this, killed the turbo on my old DT.
Honestly should have seen the shit in there
306 HDI, soon to be XUD
Threads: 155
11
(19-02-2013, 06:46 PM)declantg Wrote: (19-02-2013, 06:44 PM)silverzx Wrote: Took air filter and piping off? Should release a bit more power.
When me and dan! Took his turbo apart there was thick slime all inside it
Threads: 61
2
19-02-2013, 07:33 PM
(This post was last modified: 19-02-2013, 07:34 PM by RePT.)
Mhmm, i was under the assumption that turbo was completely wound.
How many psi am i losing here?
As with max fuel, theres 7 threads left.
Threads: 591
54
19-02-2013, 07:43 PM
(This post was last modified: 19-02-2013, 07:43 PM by Piggy.)
someone will correct me probably...but that dont look right...for a KKK
well it looks a bit wrong for any turbo
Threads: 61
2
19-02-2013, 07:52 PM
(This post was last modified: 19-02-2013, 07:55 PM by RePT.)
Whts wrong with it?
Threads: 87
48
(19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it?
it's not a K14 that's what's wrong and i still say you're a troll . . . .
and as said that's a non-standard wastegate arm . .
Threads: 61
2
(19-02-2013, 07:59 PM)Mattcheese31 Wrote: (19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it?
Is it a k03? Was advised its a k14.
Threads: 87
48
(19-02-2013, 08:02 PM)RePT Wrote: (19-02-2013, 07:59 PM)Mattcheese31 Wrote: (19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it?
by whom? . . . . .
Threads: 591
54
glad I wasnt thinking wrong...I thought 'thats not a k14'...but usually I am wrong!!
Threads: 61
2
(19-02-2013, 08:03 PM)Mattcheese31 Wrote: (19-02-2013, 08:02 PM)RePT Wrote: (19-02-2013, 07:59 PM)Mattcheese31 Wrote: it's not a K14 that's what's wrong and i still say you're a troll . . . .
by whom? . . . . .
Doesnt matter anymore :p is it the k03 though??
Threads: 87
48
(19-02-2013, 08:09 PM)RePT Wrote: (19-02-2013, 08:03 PM)Mattcheese31 Wrote: (19-02-2013, 08:02 PM)RePT Wrote: Is it a k03? Was advised its a k14.
by whom? . . . . .
not saying unless you say who it was so i can rip them . .:p
Threads: 61
2
(19-02-2013, 08:11 PM)Mattcheese31 Wrote: (19-02-2013, 08:09 PM)RePT Wrote: (19-02-2013, 08:03 PM)Mattcheese31 Wrote: by whom? . . . . .
Lol, a simple google search might pick up archive  i take its a bloodeh k03. O whai da ba tingz happenz 2 meh
Threads: 71
4
Car Model/Spec: 205 dt
Running more psi only means there is larger volume of air trying to get into your engine not that a larger power is being output
