K14 19psi, and bored! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: K14 19psi, and bored! (/showthread.php?tid=11093) |
K14 19psi, and bored! - RePT - 19-02-2013 Afternoon all, Had some fun with 19psi(and still am) but id like to up it to 24. As title suggests, i have the kkk k14. What steps must I take to achieve that 23/24 psi of boost? Running bosch with max fuel. RE: K14 19psi, and bored! - Anton - 19-02-2013 Eh? 19psi is a bog standard stage 1. Get an MBC, bet its the wastegate. RE: K14 19psi, and bored! - Piggy - 19-02-2013 wind in the turbo some more... I have a bosch, lda wound pretty far but not ground down, fuel max screw only adjusted a couple turns, k14 turbo wound all way in, then back half turn... I get 22psi at full chat RE: K14 19psi, and bored! - David - 19-02-2013 Why on earth have you maxed fuelled the the pump and not sorted the waste gate out? You must be coaling like hell? Sort the waste gate out and turn the fuel down RE: K14 19psi, and bored! - silverzx - 19-02-2013 Took air filter and piping off? Should release a bit more power. RE: K14 19psi, and bored! - declantg - 19-02-2013 (19-02-2013, 06:44 PM)silverzx Wrote: Took air filter and piping off? Should release a bit more power. DoNOT do this, killed the turbo on my old DT. Honestly should have seen the shit in there RE: K14 19psi, and bored! - David - 19-02-2013 (19-02-2013, 06:46 PM)declantg Wrote:(19-02-2013, 06:44 PM)silverzx Wrote: Took air filter and piping off? Should release a bit more power. When me and dan! Took his turbo apart there was thick slime all inside it K14 19psi, and bored! - RePT - 19-02-2013 Mhmm, i was under the assumption that turbo was completely wound. How many psi am i losing here? ![]() As with max fuel, theres 7 threads left. RE: K14 19psi, and bored! - Piggy - 19-02-2013 someone will correct me probably...but that dont look right...for a KKK well it looks a bit wrong for any turbo K14 19psi, and bored! - RePT - 19-02-2013 Whts wrong with it? RE: K14 19psi, and bored! - Mattcheese31 - 19-02-2013 (19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it? it's not a K14 that's what's wrong and i still say you're a troll . . . . ![]() and as said that's a non-standard wastegate arm . . K14 19psi, and bored! - RePT - 19-02-2013 (19-02-2013, 07:59 PM)Mattcheese31 Wrote:(19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it? Is it a k03? Was advised its a k14. RE: K14 19psi, and bored! - Mattcheese31 - 19-02-2013 (19-02-2013, 08:02 PM)RePT Wrote:(19-02-2013, 07:59 PM)Mattcheese31 Wrote:(19-02-2013, 07:52 PM)RePT Wrote: Whts wrong with it? by whom? . . . . .
RE: K14 19psi, and bored! - Piggy - 19-02-2013 glad I wasnt thinking wrong...I thought 'thats not a k14'...but usually I am wrong!! K14 19psi, and bored! - RePT - 19-02-2013 (19-02-2013, 08:03 PM)Mattcheese31 Wrote:(19-02-2013, 08:02 PM)RePT Wrote:(19-02-2013, 07:59 PM)Mattcheese31 Wrote: it's not a K14 that's what's wrong and i still say you're a troll . . . . Doesnt matter anymore :p is it the k03 though?? RE: K14 19psi, and bored! - Mattcheese31 - 19-02-2013 (19-02-2013, 08:09 PM)RePT Wrote:(19-02-2013, 08:03 PM)Mattcheese31 Wrote:(19-02-2013, 08:02 PM)RePT Wrote: Is it a k03? Was advised its a k14. not saying unless you say who it was so i can rip them . .:p K14 19psi, and bored! - RePT - 19-02-2013 (19-02-2013, 08:11 PM)Mattcheese31 Wrote:(19-02-2013, 08:09 PM)RePT Wrote:(19-02-2013, 08:03 PM)Mattcheese31 Wrote: by whom? . . . . . Lol, a simple google search might pick up archive i take its a bloodeh k03. O whai da ba tingz happenz 2 meh
Re: K14 19psi, and bored! - kernow_joe - 19-02-2013 Running more psi only means there is larger volume of air trying to get into your engine not that a larger power is being output |
