	Threads: 171
46
		Sounds about right on the first two
As for the slight grind. New gearbox oil works wonders for the feel of it and noises
	Threads: 177
		the hearers will be the resistor pack, its in the intake above the motor
	Threads: 94
		Thanks for the help! Its a gentle grind/crunch into 4th gear so shouldn't be too bad
	Threads: 94
		Going to pick this car up later, want to get the speedo sorted asap. Anyone link me to the sensor i need to buy? Its a 98 phase 2, or is there a chance i wont need one just a loose conection? Thanks
	Threads: 36
18
Car Model/Spec: DT
		Probably best to go straight to a PUG specialist garage to buy a sensor / sender.
 IIRC, To get to the sensor / sender you have to take out the driver side driveshaft anyway,  I wouldn't go through that just to check it. Id buy one and if you don't need on then send it back.
On the 306 waiting list.
	Threads: 92
43
		Syncro on 4th is worn out
![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
