Threads: 171
46
Sounds about right on the first two
As for the slight grind. New gearbox oil works wonders for the feel of it and noises
Threads: 177
the hearers will be the resistor pack, its in the intake above the motor
Threads: 94
Thanks for the help! Its a gentle grind/crunch into 4th gear so shouldn't be too bad
Threads: 94
Going to pick this car up later, want to get the speedo sorted asap. Anyone link me to the sensor i need to buy? Its a 98 phase 2, or is there a chance i wont need one just a loose conection? Thanks
Threads: 36
18
Car Model/Spec: DT
Probably best to go straight to a PUG specialist garage to buy a sensor / sender.
IIRC, To get to the sensor / sender you have to take out the driver side driveshaft anyway, I wouldn't go through that just to check it. Id buy one and if you don't need on then send it back.
On the 306 waiting list.
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
As for the fourth gear grinding - sounds a syncromesh problem pal.
Syncromesh syncronises gear ratio's when you change gear - id say difficult to repair would reocmmend a new box in time
see here for info
http://en.wikipedia.org/wiki/Manual_tra ... ynchromesh
Phaes 1 GTI 6 - Onyx Black
Threads: 92
43
Syncro on 4th is worn out
