Threads: 591
54
So this is the turbo on the 2.1 that came yesterday...
a Garrett obviously...
but this is the plate on it...no idea what it is and the numbers do nothing on the net...
the only thing obvious to me is the T2...but I thought the T2 was huge?!
any thoughts?
Piggy
Threads: 226
24
Car Model/Spec: A3 TDi
30-11-2012, 04:40 PM
(This post was last modified: 30-11-2012, 04:45 PM by Tom.)
T2's are not huge.
Edit: Googled a little bit and all i found is TBO228 says its citreon.
Edit2: From a xantia 2.1?
Threads: 591
54
(30-11-2012, 04:40 PM)Tom Wrote: T2's are not huge.
kay...
TB0228....
Threads: 124
26
Car Model/Spec: Megane DCiR
A shit one
Threads: 129
11
30-11-2012, 06:29 PM
(This post was last modified: 30-11-2012, 06:29 PM by strictly_perv.)
T2's are tiny.
That looks like a GT15 sized snail.
Stage 2 XUD Sedan
Threads: 591
54
Lol!!
Suggestions for replacement? Something not too big.. a t25?
Threads: 226
24
(30-11-2012, 06:42 PM)Piggy1987 Wrote: Lol!!
Dont bother with a t25 get a td04 if your going bigger.
Threads: 591
54
Rekon will fit behind the engine and bulkhead though?!
Threads: 226
24
(30-11-2012, 06:58 PM)Piggy1987 Wrote: Rekon will fit behind the engine and bulkhead though?!
Behind a 1.9 yes
Behind a 2.1 not a clue.. but doubtful.
Threads: 591
54
exactly...hence my issue!!
Threads: 91
83
Thought you didn't like revvy diesels?
If you don't, stay stock....
Threads: 198
135
(30-11-2012, 06:54 PM)Tom Wrote: (30-11-2012, 06:42 PM)Piggy1987 Wrote: Lol!!
Pfft td04?
SO last year
Threads: 591
54
02-12-2012, 08:18 PM
(This post was last modified: 02-12-2012, 08:19 PM by Piggy.)
(02-12-2012, 08:01 PM)Ruan Wrote: Thought you didn't like revvy diesels?
man when a cat gets a rat....
just dont like huge boost delay and plooms of smoke
(02-12-2012, 08:13 PM)cwspellowe Wrote: (30-11-2012, 06:54 PM)Tom Wrote: (30-11-2012, 06:42 PM)Piggy1987 Wrote: Lol!!
Pfft td04?
SO last year
lol...so am i so would suit!! haha
Threads: 91
83
Well don't get a TD04 or a T25...
Do some research into bigger but better turbos... Bigger =/= better but at the same time, bigger doesn't necessarily mean more lag if you choose well...
Threads: 591
54
ok...fair comment...what would you suggest?
Threads: 91
83
Do some research and find out what would be best, I've written my opinion on turbos countless times, have a look through some previous posts, I've explained how A/R, wheel sizing and efficiency affects things, you should make your decision based on this
Threads: 591
54
Threads: 198
135
To be honest, even if you found a more efficient newer equivalent of the T2 you'd make decent power, I worked out my T2 at 28psi was about 60% or less efficient, if you could find one that operates at 75%+ efficient with the same flow you'd see good improvements as the less efficient they get, the more they just make heat instead of flow.
As Ruan said though, reading is your friend. I just spent a month and two turbos getting a setup that works and it's epic. It's so much more rewarding knowing you've gone out, looked into something and made it work, especially when it's different to the norm.
Anyone can buy a td04 and a set of adapter plates and make it work, but that's no fun
Threads: 591
54
(02-12-2012, 08:38 PM)cwspellowe Wrote: To be honest, even if you found a more efficient newer equivalent of the T2 you'd make decent power, I worked out my T2 at 28psi was about 60% or less efficient, if you could find one that operates at 75%+ efficient with the same flow you'd see good improvements as the less efficient they get, the more they just make heat instead of flow.
thats true...
Threads: 266
18
Car Model/Spec: 205 DTurbo
Nothing wrong with a T25 shlags!
Threads: 124
26
(02-12-2012, 08:38 PM)cwspellowe Wrote: Anyone can buy a td04 and a set of adapter plates and make it work, but that's no fun
i used to like you
haha it will be fun making a (genuine) hybrid TD04 setup which will be unlike the norm
Threads: 198
135
Mountie lad has done that already sir, remember the 19twentyT with a gazillion torkz?
Threads: 124
26
HAHAHA oh shitt no that was a 18g turbine off a TD05
Well mines a 15g already but going for the 19T soon  need to make bulkhead adjustments though, got a tap atm and its annoyin fink its just heatshield on steerring rack tapping but cant see haha
Threads: 198
135
Pfft, I chopped 10" of bulkhead away, loads of clearance now. Did a turbo change with the engine in situ
Threads: 124
26
(03-12-2012, 12:29 PM)cwspellowe Wrote: Pfft, I chopped 10" of bulkhead away, loads of clearance now. Did a turbo change with the engine in situ
hahaha quality my thinking on next time its coming out for drilling and tapping head so can bolt all 6 bolts in manifold as opposed to 4
Threads: 591
54
Think may make more room even if not needed while the engine is out...appears to be something needed for the future!!!
