Threads: 202
58
As in title, I have had a really good search and can't find the info I need..
Firstly, does anyone know if this is possible, I.e, will the GTi6 box fit in the first place?
Secondly, I assume I will have to change the final drive to one off a diesel to get the revs down (ideal would be just under 2k RPM at 70MPH)
Just messing with ideas at the moment, this would be a project for when I change the clutch.
Cheers,
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Iirc yes it will fit and yes the ratios are horribly wrong as the 6 goes 2k further up the rev guage?
I think the top speed wohld have been like 90 if you keep the gears
Threads: 202
58
Why can't I use the final drive from a HDi box?
Is it as simple as it won't fit or am I missing the point here?
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
The 6 F/D is longer than the hdi one IIRC.
Threads: 189
10
Yea, a 6 speed hdi box, but its a ball ache to fit it and get everything working.
Threads: 86
2
A lad over on TDOCUK fitted a 6 box to an XUD, think top speed is 105
Threads: 13
4
Car Model/Spec: 306 Rallye // Saab 9-3 Aero.
Bet it accelerates like the clappers though!
Threads: 82
27
Doubt it, you'd probably spend more time changing gear than in gear lol
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Then theres changing the steering rack aswell
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
