1.6 fps wiring
Cant remember which two wires require being swapped for the 1.6 fps to work. Anyone recall as cant find the original post and old looms been scrapped.
Also after where the power leads go for the starter. Believe it goes battery>starter>alternator but its been so long since i removed it i cant remember [Image: c2cb582d8ab18b8bc7524f9b24631a2a.jpg]
Sent from my BLA-L09 using Tapatalk
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Saw this thread and could not help but think of Counter-Strike.
Sorry I know thats absolutely no help whatsoever.
Battery-starter-alternator is correct. Can't remember which wires need to be swapped on the frps, sorry.
(06-07-2018, 06:30 PM)Poodle Wrote: Battery-starter-alternator is correct. Can't remember which wires need to be swapped on the frps, sorry.
Thank you!
Justin_306DTurbo
Never swapped the sensor over but I believe it's wires 1 + 2 need swapping. I think wire 3 is +5v.
(22-07-2018, 10:58 AM)Uberderv Wrote: Never swapped the sensor over but I believe it's wires 1 + 2 need swapping. I think wire 3 is +5v.
Am i right in thinking that the wires needed swapping then for the 1800 bar fps swear i read it somewhere ages ago
Justin_306DTurbo
Yes that's right - if you're using a 1920.GW from a 1.6HDi you need to swap wires, the pinout is different.
Can't remember which wires need swapping though.
EDIT: Because I'm really good to you, just went and found diagrams -
1.6HDi
1 - Ground
2 - Signal
3 - +5v
2.0 8v HDi
1 - Signal
2 - Ground
3 - +5v
So in answer, yes, 1 & 2 need swapping.
