HG failure?
Found this lovely brown grease type stuff on the water cap, should I worry or is it just how XUD's are?
[attachment=18313]
It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm?
(10-08-2014, 07:33 PM)JJ0063 Wrote: It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm?
No it's been perfect. Just checked on the off chance and noticed it, anything I can do to help it?
I have never seen sludge on any xud I've witnessed with hgf
Oil cooler may have shit itself and leaking oil into the coolant
Team Doesn't own a 306
(10-08-2014, 07:46 PM)Danny2009 Wrote: I have never seen sludge on any xud I've witnessed with hgf
Shit, can this be fixed?
It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol.
(10-08-2014, 07:55 PM)Toms306 Wrote: It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol.
:/ hope it fixes it, is it safe to drive like this?
I'd wipe the cap put it back on and carry on like nothing's changed
Just keep a eye on the temp gauge a quick glance over now and again
Wouldn't worry me tbh
Personally I'd flush out the coolant system and see if it returns...
Yeah it's safe to drive as long as you keep an eye on it.
(10-08-2014, 07:59 PM)Danny2009 Wrote: I'd wipe the cap put it back on and carry on like nothing's changed
(10-08-2014, 08:00 PM)Toms306 Wrote: Personally I'd flush out the coolant system and see if it returns...
That's good news then Smile can anyone find me a pic of what the oil cooler looks like? I can keep an eye out for one then
Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp
(10-08-2014, 08:09 PM)Stevo-trendy Wrote: Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp
Yeah I work 10 minutes away, should I drive a little longer?
Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out
(10-08-2014, 08:55 PM)Stevo-trendy Wrote: Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out
Sweet ill have to do that
