10-08-2014, 07:31 PM
10-08-2014, 07:33 PM
It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm?
10-08-2014, 07:41 PM
(10-08-2014, 07:33 PM)JJ0063 Wrote: [ -> ]It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm?
No it's been perfect. Just checked on the off chance and noticed it, anything I can do to help it?
10-08-2014, 07:46 PM
I have never seen sludge on any xud I've witnessed with hgf
Oil cooler may have shit itself and leaking oil into the coolant
10-08-2014, 07:50 PM
(10-08-2014, 07:46 PM)Danny2009 Wrote: [ -> ]I have never seen sludge on any xud I've witnessed with hgf
Shit, can this be fixed?
10-08-2014, 07:55 PM
It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol.
10-08-2014, 07:57 PM
(10-08-2014, 07:55 PM)Toms306 Wrote: [ -> ]It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol.
:/ hope it fixes it, is it safe to drive like this?
10-08-2014, 07:59 PM
I'd wipe the cap put it back on and carry on like nothing's changed
Just keep a eye on the temp gauge a quick glance over now and again
Wouldn't worry me tbh
10-08-2014, 08:00 PM
Personally I'd flush out the coolant system and see if it returns...
Yeah it's safe to drive as long as you keep an eye on it.
10-08-2014, 08:04 PM
(10-08-2014, 07:59 PM)Danny2009 Wrote: [ -> ]I'd wipe the cap put it back on and carry on like nothing's changed
(10-08-2014, 08:00 PM)Toms306 Wrote: [ -> ]Personally I'd flush out the coolant system and see if it returns...
That's good news then can anyone find me a pic of what the oil cooler looks like? I can keep an eye out for one then
10-08-2014, 08:09 PM
Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp
10-08-2014, 08:29 PM
(10-08-2014, 08:09 PM)Stevo-trendy Wrote: [ -> ]Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp
Yeah I work 10 minutes away, should I drive a little longer?
10-08-2014, 08:55 PM
Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out
10-08-2014, 09:53 PM
(10-08-2014, 08:55 PM)Stevo-trendy Wrote: [ -> ]Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out
Sweet ill have to do that
