Threads: 3
Had the ignition turned on for quite a while yesterday (by the wife and I forgot it was turned on) and the battery was then too flat to start the car :oops: . A quick jump start and off she went, but it seems the fan is running all the time. It seems to have new fangled climate control and no matter where you position the fan switch it keeps on running. If you turn the fan speed up it does increase but there is only a minimum and an "auto" setting. No manual so not to sure if this is a fault or if it supposed to be like this? :? Otherwise must just remember not to leave the ignition switched on for long periods of time - which will never really happen in any case.
Threads: 465
114
Car Model/Spec: Vauxhall
yup they always run even when off remember to turn the ign off!
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Check the plug at he top of your rad also. Should have the cables going into it, if one is broken, fan can stay on even when the engine isn't running.
Phaes 1 GTI 6 - Onyx Black
Threads: 465
114
to the point as always connor!
i believe connor is pointing to the fact that the OP is refering to heater internal fan
NOT the rad cooling fan
Threads: 376
38
/sigh
