19-03-2012, 07:52 PM
Had the ignition turned on for quite a while yesterday (by the wife and I forgot it was turned on) and the battery was then too flat to start the car :oops: . A quick jump start and off she went, but it seems the fan is running all the time. It seems to have new fangled climate control and no matter where you position the fan switch it keeps on running. If you turn the fan speed up it does increase but there is only a minimum and an "auto" setting. No manual so not to sure if this is a fault or if it supposed to be like this? :? Otherwise must just remember not to leave the ignition switched on for long periods of time - which will never really happen in any case.
